Old 01-26-2020, 05:26 AM   #1
2018 30' Classic
Williamsburg , VA
Bed doesn't stay up
Does this happen to anyone else? It stays up without the comforter on but the comforter is always on so my bed does not stay up. I have back issues so it has become a pain. Does anyone have a recommendation on a different strut that will hold it up?
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 01-26-2020, 05:54 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
We have a mattress topper on ours so the bed doesnít stay up. I usually hold it for my wife if she needs access below. We only put items that we donít need often below the bed.
You can replace the struts with stronger ones. Same brand and size, just a higher weight load. You can also flip the comforter to the head of the bed, get access, and then flip it back if you donít want to go through the hassle of replacing the struts.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 01-26-2020, 05:57 AM   #3
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
I found if the bed is all the way flat when I raise it it will stay up but if the head of the bed is raised at all when I lift it it will not stay raised by itself.
JDG is offline   Reply With Quote
Old 01-26-2020, 06:23 AM   #4
2018 30' Classic
Williamsburg , VA
That is the same for me if there is no comforter on it. However with the comforter even with the head down it does not stay up.
2018 Classic 30
2012 F250 6.7l
Old 01-26-2020, 06:31 AM   #5
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Replacing the struts is not that hard. We have a mattress topper and the comforter and it stays up.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 01-26-2020, 06:55 AM   #6
JDG
Riveted
JDG's Avatar
2018 33' Classic
Does anyone have model number of stronger struts that will work?
Old 01-26-2020, 09:02 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I would....call the manufacturer with the make, length & pressure numbers, explain the problem and go from there.
I had to do the same for a floppy boat hatch.🤓
Obrigado, ť hora de descansar.
Tahawus
Old 01-26-2020, 09:14 AM   #8
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Hi PrimePower,
By googling "Aristream Bed Lift" I found quite a few Airforums threads on this topic. Here is a pertinent one: http://www.airforums.com/forums/f46/...ift-92424.html
SuperTrouper is offline   Reply With Quote
Old 01-26-2020, 10:26 AM   #9
2000 30' Excella
Sarasota , Florida
Use a stick to keep it propped up
GatorDave is offline   Reply With Quote
Old 01-26-2020, 12:54 PM   #10
Mollysdad's Avatar
I wanted to replace a strut once, and I wrote down the serial number.
I took that 8 digit number and entered it in Amazon's search bar....nothing else and I'll be darned if it didn't return the exact strut.
So, try a search and look for a stronger one!
Don't go too strong or the bed might hit you in the face when you bump it accidentally.
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Microwave Drawer doesn't stay open dekew Stoves, Ovens & Microwaves 3 04-04-2011 12:26 PM
Trailer Battery doesn't stay charged morrowtimber Batteries, Univolts, Converters & Inverters 12 03-20-2011 10:53 AM
Dometic fridge doesn't stay cold when travelling Work2play Refrigerators 9 06-23-2009 07:15 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
