Old 06-26-2018, 07:35 AM   #1
Vonore , Tennessee
Battery on off switch
Easy question. Is battery on off switch on 2017 Classic on or off when plugged into shore power?
Laurai is offline   Reply With Quote
Old 06-26-2018, 07:57 AM   #2
2018 30' Flying Cloud
Gig Harbor , Washington
Hi,
Plenty of information in this thread, with very detailed steps and schematics.
http://www.airforums.com/forums/f542...ll-168120.html
hoagy_007 is offline   Reply With Quote
Old 06-26-2018, 08:44 AM   #3
Mollysdad's Avatar
Mine says, "Use/Store", not on/off.
In use, the converter supplies 12 v. to all the lights, controls, and other devices requiring 12v. AND charges the batteries.
In "store" it does not supply 12 v, and does not charge the batteries.
Shore power is 120 vac, for the A/C and outlets, and powers the converter when in "Use".
Mollysdad is online now   Reply With Quote
Old 06-26-2018, 11:21 AM   #4
2007 22' International CCD
Where the confusion often comes in, is the fact that the light next to the use/store switch DOES NOT indicate the state of the actual use/store latching relay. The light ONLY indicates 12 volt power is present on the trailer side (12 volt appliances and lights) of the latching relay.
So, if the trailer is plugged into 120v AC shore power, and the convertor is working, the light will be ON. This does NOT always mean that the battery is being charged. There are some wiring differences between years that affect this. For example, my 2007 ONLY charges batteries from the convertor when the relay is closed.
My aftermarket, DIY solar system (150 watt AMSolar kit) is wired so the batteries always get charged from the MPPT solar controller when in storage. I also generally leave the use/store switch set to "USE" so I can run one Fantastic fan to keep the AS ventilated up here in the hot, high desert in SoCal. The MPPT controller does multi-stage charging and also has a temperature sensor to help protect the batteries from overcharging in the desert heat. It's been getting well over 100 degrees where we store the AS!
For ALL AS trailers, if the Use/Store relay is in the "USE" position, the batteries are connected to the trailer 12 volt appliances. If the relay is set to "STORE", the batteries are NOT connected to the trailer 12 volt appliances. The only way to verify this is to press the desired side of the switch, and listen for the 'clunk' from the latching relay. If shore power is NOT connected, the red light should then come on.
It's a little weird because Airstream used a very simple (read as: Cheap, and draws NO power when open or closed--just briefly when you hit the switch) latching relay product that does not give a real indication of the relay being on or off. Blue Sea systems makes a relay with a positive indicator LED, however, that relay draws a little power all the time to keep the LED in the switch on when the relay is on. I plan to replace Airstream's cheapo latching use/store relay and independent light with a Blue Seas Systems ACR so I know what's really going on...and this has a manual override as well so I can close the relay if the batteries are too dead to latch this thing.
Link: https://www.amazon.com/Blue-Sea-Syst...%2Bswitch&th=1
Old 06-26-2018, 04:05 PM   #5
Vonore , Tennessee
Yes, no light to indicate anything, like those cheapy power strips you can buy in 2 packs at Walmart. Obviously on is the answer. When we store we “off”. Turns off all light panels and gas detector.
Old 06-26-2018, 04:06 PM   #6
Vonore , Tennessee
We been having converter problems. Then all dumb questions come back into play.
Old 06-26-2018, 05:29 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There is another layer to this. Not all trailers are wired the same way. Some do one thing, others work a different way. "Fixing" the difference is simply moving a cable from one lug to an adjacent lug.
uncle_bob is online now   Reply With Quote
Old 06-26-2018, 05:52 PM   #8
Hi
Yup. Had to do that to get the Solar Controller onto the batteries at all times--was on wrong side of the latching relay initially. Every time the sun came out, the use/store red LED came on, and we could not figure out what was going on. To add to the fun, it was set to 'store', so scratch one set of batteries...after about six months of this silliness...
If you need to do this, please disconnect battery negative cable AND all shore power to prevent sparking and arcing where you are messing with the wiring. I had to crawl under our bed to do this fix, and that is NOT a good place to start an electrical fire...
Old 06-27-2018, 02:39 PM   #9
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Our battery store switch turns off everything in the trailer except the Co2 monitor and fire monitor as well as the ability to charge the batteries using our solar system. The solar by passes the converter.
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
Old 06-27-2018, 02:58 PM   #10
Long Island , New York
One easy way to check your Use/Store switch is to manually turn on the overhead lights, then try the U/S switch, both with and without shore power. Check your battery voltage during each step of the testing.
This full-scale-model testing is a lot more practical than getting advice here, because not all models have the same switch, and sometimes Airstream even puts different parts in different trailers, even in the middle of the same run of each model in the same model year! Yes, you read that right. There have been reports of workers on the assembly line swapping in non-standard parts for “your” part, just to keep the line moving.
So . . . get to know your specific trailer based on your own testing.
Good luck,
Peter
PS — I guess your 30’ Classic has its own system, however, the point remains that your best approach is to put all the settings through all the options as suggested above, without taking as gospel other folks’ advice.
LPG Detector turns off with Multiplex Battery Disconnect switch Alex AVI Sprinter and B-van Forum 10 03-20-2018 08:28 AM
Battery Switch Inside "On" or "Off"? Cannonball Batteries, Univolts, Converters & Inverters 15 12-08-2016 07:57 PM
Battery Switch Off: Turned On; No power. Did it Discharge? ezra@ezraboo Batteries, Univolts, Converters & Inverters 2 07-24-2016 08:36 AM
BATTERY ON/OFF SWITCH - What Do I Do? Fly at Night Batteries, Univolts, Converters & Inverters 36 08-30-2011 08:24 PM
battery switch off - fridge running Joyce and Jim Batteries, Univolts, Converters & Inverters 4 08-28-2009 08:35 AM
