Old 04-23-2020, 10:54 AM   #1
2019 30' Classic
Belen , New Mexico
Another AT&T irritation on the Classic connectivity
Don't know what router the 2020s are using, but the 2019 uses a Pepwave MAX BR1 mini with a Cat 4 modem. I have been to several sites where AT&T coverage was supposed to be good and it really struggles. I may have found the problem.
Looking at the router specs:
Cat 4 frequency bands: B2, B4, B5, B13, B17
As it turns out, AT&T has a significant usage of the B12 band. In order to use it, you have to have the Cat 6 version of the router.
Now you know.
Ephraim is offline   Reply With Quote
Old 04-30-2020, 06:20 AM   #2
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
So is there a solution? Is there something we can do to solve this? The best solution would be to get away from AT&T but if that isn't possible can we switch to a more current Pepwave but still retain the trailer's functionality?
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
Froglips is offline   Reply With Quote
Old 04-30-2020, 06:46 AM   #3
ChipB's Avatar
2020 33' Classic
St Tammany , Louisiana
Now you know.
I'm experiencing similar connectivity and speed issues in areas where the ATT map indicates I should not have issues. I'm hoping for an answer as well. If it's a router upgrade, OK. If it's a switch to another carrier, OK. If it's both, well, that's an answer, and OK as well. I'll watch this thread for replies from those in the know.
ChipB is offline   Reply With Quote
Old 04-30-2020, 10:29 AM   #4
2020 Classic 33
Box Elder , South Dakota
Specs I see on the Peplink site include B12.
Product CodeRegion/CarrierEmbedded Modem4G Bands3G Bands 4G LTEMAX-BR1-MINI-LTE-US-TUnited States14G LTE:
B2, B4, B5, B12, B13HSPA+: B2, B5
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 04-30-2020, 07:16 PM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Now you know.
Att Netgear nighthawk is a cat 16 modem with 4x4 MIMO antennas. Verizon 8800L is cat 18 with 4x4 MIMO antenna.
Each are about $200 bucks.
Iíve been working in the trailer this past week. Pushed about 200 gigs of data through my Verizon Inseego 8800L. I am one of the fortunate few who jumped on the $69/mo prepaid unlimited / unthrottled (but network managed) plan from 1.5 years ago. Works like a charm.
I regularly enjoy speeds of 25-75Mbps.
wulfraat is online now   Reply With Quote
Old 04-30-2020, 10:43 PM   #6
2019 30' Classic
Belen , New Mexico
B12, B13, B17, and B18 are all on 700MHz.
Peplink says they have B12, but not B17.
5gstore.com lists it as having B17, but not B12
The Cat6 version says it has B12/17 and B13
I'm going to order one and swap the default modem out. This will allow me to mess with the router, but not mess with stuff that Airstream warranties. I'll see how much functionality is retained. In a conversation I had with Airstream a while back, they indicated that the smart control was not tied to AT&T. I suspect that the modem loads GPS data to an airstream server somewhere (for your location data.) It could be part of peplink's InControl system or it could be a separate server because the BR1 mini supports both.
I really don't care about location data. What I care about is having connectivity when I should have it, even if that means switching carriers.
Old 05-01-2020, 02:49 PM   #7
2018 30' Classic
Williamsburg , VA
So what make and model did you purchase exactly?
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 05-02-2020, 06:02 AM   #8
2019 30' Classic
Yea, interested in how much functionality you lose. I can buy a hot spot for a fraction of what those modems cost.
Old 05-02-2020, 12:39 PM   #9
2018 30' Classic
Williamsburg , VA
You can but you won't get the signal inside the Airstream like the connected antennae does.
2018 Classic 30
2012 F250 6.7l
Old 05-02-2020, 09:47 PM   #10
wulfraat's Avatar
It all depends on the conditions. I have an external Omni directional 1x1 antenna on the roof, 2x2 portable directional MIMO antenna I place in a window, and my jetpack 8800l has a built in omni directional 4x4.
85% of the time I use my 2x2 directional and place with the best orientation. 10% of the time I use the jetpack antenna and place the unit in a window, 5% of the time I use my roof antenna (most expensive of them all interestingly enough).
Ultimately I think a 4x4 roof mounted antenna would be best, but I have not seen any cost effective consumer cat 18 LTE modems with the ability to connect to an external 4x4... they all seem to be 2x2 outputs from the modem hardware, including both fixed and portable modems.
The best is to have multiple options available, and choose the one that works best for the circumstances. There is no question that a category 18 modem will outperform a cat 6 in most of not all situations as it can multiplex / aggregate channels for improved throughout.
Old 05-07-2020, 12:18 PM   #11
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Now you know.
Hi,*
Please don't hesitate to reach out to us so that we can assist by sending us a direct message with your contact information and the last 6 digits of your VIN.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Travel w/Verizon Jetpack for Connectivity Hittenstiehl Working on the Road 20 11-11-2013 02:23 PM
Internet Connectivity Rdiddly Friends of Dorothy 14 06-30-2012 08:28 PM
Greetings from VA - Connectivity issue lluquis Member Introductions 11 11-17-2007 09:42 AM
univolt/converter connectivity fwiz Mechanics Corner - Engines, Transmission & More... 3 04-19-2005 10:05 PM
Connectivity issues... Andy R Our Community 8 10-29-2004 07:42 PM
