Old 07-16-2020, 12:17 PM   #1
AeroHead Aviation
tjmartini's Avatar
2018 30' Classic
Simpsonville , South Carolina
Another Alde Question
Problem: No power to the Alde system, screen fault, “ Red connection fail”
History: 2018 Classic 30 always plugged in to electric power and used at least every other weekend when not traveling. The Alde system was on for heat and hot water all winter. I drain the tank periodically to renew the air cushion. Three weeks ago, when the weather got warm, I shut off the system entirely, heat and water. This past weekend I turned the system on and got a “Red connection fail” fault.
Alde Manual: Connection failure: There is a connection fault between boiler and panel. To reset, disconnect 12 V from the boiler and reconnect.
Actions: I switched the 12 V disconnect button to off and then on, the fault remained. I searched the internet and Forums, including Much ado about Alde and only found “Overheat red failure”. The YouTube vids showed how to disconnect the wires then reconnect them. I did this with no success, the fault remains.
Questions: Has anyone experienced this problem? How do I reset the system? Which wire is the 12 V the manual is referring to? How can I contact Alde USA?
Thomas Martini
GE Mechanical Drivetrain Test Engineer
Skydive Carolina Pilot
2017 GMC 2500HD, 2018 Airstream Classic 30, Propride 3P
South Carolina WBCCI Region #3, Unit #22, #18675
tjmartini is offline   Reply With Quote
Old 07-16-2020, 02:06 PM   #2
Sparr's Avatar
Casa Grande , Arizona
Truma/Alde USA (877) 860-9814
Steven & Lisa
"Olivia" 2017 Airstream Classic 30
2016 Dodge Ram Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
WBAC (WBCCI) Region 11 1st VP - Life Members # 5523, AIR # 118556, KJ6DKF
Sparr is offline   Reply With Quote
Old 07-16-2020, 09:08 PM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Truma is super helpful on the phone and not a long wait at all. They could probably walk you through the reset process over the phone and prevent a visit to a dealer. Hopefully it’s something simple and not a main board issue. Just replaced mine, shipping was fast and installation was easy... just cost $200 for the panel.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 08-22-2020, 11:55 AM   #4
2020 33' Classic
LOS ANGELES , California
This has happened to me once or twice. Hitting the battery disconnect switch and waiting a minute reset the issue for me.
airmcquinn is offline   Reply With Quote
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 58 05-01-2021 09:34 PM
Yet Another Alde Related Mystery uncle_bob 2016 - Current Classic (all lengths) 26 06-25-2018 09:08 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 03:39 PM
