Old 02-09-2020, 04:57 PM   #1
2019 30' Classic
BOONE , Iowa
Alde - Service needed
We are traveling with our new to us 2018 Classic and the Alde system is not working. No heat and no hot water. Can someone recommend a service center or mobile tech who is knowledgeable about the system. We will be going through Birmingham, Montgomery and Savannah. I would really like some heat and hot water though before we get to Savannah. Right now we are in Memphis and had an appointment set up but have been warned away from the dealership. Alde knowledge is the key request. Thanks for your help!!! I want a warm night and a hot shower!
Cejones4210 is offline   Reply With Quote
Old 02-09-2020, 05:07 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Have you guys gone through the trouble shooting already? May just need a simple reset?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 02-09-2020, 05:14 PM   #3
2019 30' Classic
BOONE , Iowa
Alde errors
When we turn on the system the light is red, I thought it was supposed to be green. On electric only, nothing happens after hours of waiting. On gas, it worked one night, but the next when we turned it on we received flashing warning lights ďgas failure ď. I know the propane is on with full tanks and stove works, but nothing on the Alde. No heat and no hot water. We need help!
Old 02-09-2020, 05:17 PM   #4
2019 30' Classic
BOONE , Iowa
After reading, husband is still not sure how to do a reset. This is our first time out with it.
Old 02-09-2020, 05:48 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
I have no experience with Alde other than taking a look at a new trailer.
Maybe this video will help.
I also remember seeing a red reset button on the display, under the tools (wrench symbol on the display). I have no idea what that reset button does, just remember seeing it.
and another troubleshooting video>
Good luck!
Alan
Old 02-09-2020, 06:06 PM   #6
2018 30' Classic
You can try doing the battery disconnect truck first. Go to the panel by the door and hit the disconnect button. Give it 30 seconds and then flip it back on.
When I had the gas failure it was because I ran out of propane and when I switched tanks I failed to reset the Alde. The fridge will do the same thing and flash LP and will need a reset to correct it.
Let us know if the reset works. Is your Alde panel under the sink or by the firefly?
BigSxyWhtGuy
Old 02-09-2020, 06:38 PM   #7
2019 30' Classic
BOONE , Iowa
I did do the battery disconnect and when I turned the Alde system on the light turned green. Yea!! We hit the propane button and water button. The glycol is gurgling. So we will wait and see if it heats.
The panel is by the firefly. Thanks so much!!
I’ll let you know if we get heat and hot water.
Old 02-09-2020, 06:59 PM   #8
2018 30' Classic
Iíll let you know if we get heat and hot water.
Perfect! 9/10 that reset method fixes most of the electrical problems you will encounter. There is a great Alde thread on here too that has a wealth of knowledge if you have the time to read it.
Have fun
BigSxyWhtGuy
Old 02-10-2020, 10:28 AM   #9
2018 30' Classic
Yorba Linda , California
Sounds like you found your answer! Yay! We had the same problem with our 2018 30’ Classic on our maiden voyage. Of course the dealer was closed, so no help there. A google search taught me a lot! I learned about the reset/control way under the kitchen sink and discovered we had blown a fuse.
We just received a letter from Airstream that they want us to bring our trailer in for an Aldi Inspection, flush and upgrade the glycol used, free of charge. You May look into this as well.
Safe travels!
CarrieAnn is offline   Reply With Quote
Old 02-10-2020, 10:44 AM   #10
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
When you have some time (weeks) there is some user experience-corporate knowledge collected in the thread, Much Ado About Alde. Started with the new '17 Classic ALDE's and moved on to the '18 ALDE and beyond. A few secrets and tricks are there that might be helpful.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 02-10-2020, 10:47 AM   #11
Obviously-NOT
Kalispell , Montana
Safe travels!
Wah??? Be sure to keep all letters, documentation, printed emails, receipts, etc. for the life of the trailer.
Old 02-10-2020, 01:26 PM   #12
Vonore , Tennessee
Low fluid
Gurgling to me means low fluid / or air in Alde lines. See what your book recommends for that. Purchase Fluid at dealer. Use no other.
We fill ours in the bathroom cabinet. Bleeding lines in front of unit and towel bar is usually enough.
Laurai is offline   Reply With Quote
Old 02-11-2020, 06:02 PM   #13
2019 - 33' Classic
RickyNelson's Avatar
2019 33' Classic
Grand Junction , Colorado
Following - thank you!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
RickyNelson is online now   Reply With Quote
Old 02-24-2020, 09:21 AM   #14
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Cejones4210,*
Did you get everything figured out? If you still need assistance, please don't hesitate to reach out to us by sending us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 58 05-01-2021 09:34 PM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
What Alde system does Airstream Use. Lets travel Classic Motorhomes 14 10-12-2016 06:54 AM
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 03:39 PM
