Old 06-15-2021, 11:23 AM   #1
frisco , Texas
Question Alde 3010 upgrade
I have a 2018 33 FB Classic. With the Alde 3010 I have inadequate hot water supply for showering. Alde states I can install the Alde flow system to supplement mr 3010 system. Has anyone completed this upgrade or have any knowledge or advice?
Thanks!
Bv60462
BV60462 is offline   Reply With Quote
Old 06-15-2021, 11:46 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
You might already have the alde flow? Our 30 2018 did. You can check by removing the bench panels to give you access to the flow unit. Itís a red box the size of a small package right next to the main alde unit.
We can also go through trouble shooting steps if you want? We had our 3010 dialed in and performance was fine. Couldnít take a 20 minute shower but it took care of us for a couple of years before springing a leak.
We recently traded up to the 3020 unit. Itís incredibly similar but completely different in performance. That was an expensive option though and should be a last resort.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 06-15-2021, 01:32 PM   #3
frisco , Texas
Thanks for the information. Mine does not have the flow as I think it was one of the earlier models. I'm glad to hear it fits in the space. Who did your upgrade?
Old 06-15-2021, 04:04 PM   #4
2018 33' Classic
Las Vegas , Nevada
ID:	397515 I have a 33 Classic here is a photo of my Aldi with the Flow unit. Donít know my build date but looks like delivered in October 2018.
ejs5405 is offline   Reply With Quote
Old 06-15-2021, 04:08 PM   #5
2018 33' Classic
Las Vegas , Nevada
Alde 3010 upgrade
Hey, I am having a problem on my Alde heat. The glycol pump works on the continuous mode but will not function on the Therm mode. I see in the Alde manual that the pump is activated by a panel room sensor. Any idea what and where this sensor is located? Thanks
Old 06-15-2021, 04:39 PM   #6
2018 30' Classic
My panel room sensor is above the sink mounted to the underside of the upper cabinet. Little black sensor that says alde on it. My panel was originally located under the sink, donít know if the sensor location was moved elsewhere when they started mounting on the wall.
BigSxyWhtGuy
Old 06-15-2021, 05:11 PM   #7
2018 30' Classic
I took delivery of my 2018 30 in November of 2017. For the first few months of the 2018 models, the control panel was under the sink because firefly took care of alde controls. They moved controls back to the multiplex wall shortly after hearing all the alde issues. Iím surprised that you donít have a flow if our early model had it.
We ended up upgrading directly with Truma/Alde. There was a satellite location in Florida that was very close for us and made it nice and easy.
BigSxyWhtGuy
Old 06-16-2021, 09:12 AM   #8
2018 33' Classic
Las Vegas , Nevada
Is this the sensor?Click image for larger version
ID:	397569Click image for larger version
Old 06-16-2021, 11:43 PM   #9
2018 30' Classic
Maybe? My black plastic cover looks similar to yours but mine says alde one it.
BigSxyWhtGuy
Old 06-17-2021, 12:19 PM   #10
2018 33' Classic
Ancaster , Ontario
Originally Posted by ejs5405 View Post
The picture you posted is the temperature sensor for the Firefly panel. The ALDE temperature sensor is smaller and located over the forward side of the sofa. Put your hand over the sensor and see which temperature reading goes up. Thatís how I discovered our Firefly temp sensors were wired backwards. The back sensor recorder the increase on the front.
Happy-rver is offline   Reply With Quote
Old 06-21-2021, 06:58 PM   #11
frisco , Texas
you were right, I do have the Alde flow on my system. Unfortunately, Airstream is no help. They have no clue that it is equipped with the Flow. I've called Alde and they are not much better. I've asked for a dealer who is familiar with the system and haven't been able to find anyone. you mentioned trouble shooting steps. Where do I find this?
BV60462
Old 06-21-2021, 10:15 PM   #12
2018 30' Classic
Trouble shooting is just through users on here if you have already gone through everything at a service center.
Usually people start with ensuring the valves are all set in the correct orientation, shower booster is being used, firefly is all updated to v3.8, circulation pumps (there are two) set to 2.
Let us know what you find.
BigSxyWhtGuy
Old 06-27-2021, 08:09 PM   #13
frisco , Texas
Update
After many calls with Airstream, I found a reliable source. John! He seems to know much about everything. He was very patient and understanding of the issues and provided what I believe is good guidance on how I can maximize the hot water that the 3010 delivers. Owning and using a RV requires you to know about how they operate. When on the road, you have no choice than to learn how to fix problems so you can enjoy your journey!
Old 06-30-2021, 04:43 PM   #14
2018 33' Classic
Las Vegas , Nevada
Dealer and Truma think my pump is bad. Makes little sense to me since it will run on continuous mode, the pump only has a red power wire and a black ground. Since something has to tell it on or off, seems like a control board or bad Alde sensorÖÖÖ.
Old 07-03-2021, 09:39 AM   #15
DeltaRon's Avatar
Cumming , Alabama
All of you who,unfortunately, bought an experimental Classic 33 with original Alde 3010 thru FireFly should hold your breath. My 2018 Classic 33 has been in repair for over 400 days with a bad circuit board. Airstream refuses to rectify because out of warranty. Alde/Truma tells my dealer that they donít make replacement boards for Alde 3010 anymore. For now we own a ďtop of the lineĒ Airstream that has no heat or hot water. Only fix may be to convert to Alde 3020 systemóóat our expense. Alde system has never worked properly since bought new in 2018.
DeltaRon is offline   Reply With Quote
Old 07-04-2021, 12:18 PM   #16
frisco , Texas
I may be able to provide you with guidance as I have the experimental model like you. I have been able to get my unit operational however I have had to go around my dealership. They know less than most of the people on this forum. Please send me an email with your number and Iíll call. Much easier explain on phone.
Old 07-05-2021, 05:34 AM   #17
DeltaRon's Avatar
Cumming , Alabama
Alde 3010
roncannon@comcast.net
(678) 591-1058
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 60 07-08-2021 11:49 AM
Anyone using an alde 3010 rugjenkins General Repair Forum 3 05-01-2021 09:39 PM
Alde 3010 control board Airhead2018 2016 - Current Classic (all lengths) 3 02-02-2021 07:34 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
