Old 03-02-2023, 01:24 PM   #1
2020 33' Classic
Greenville , Pa
Alde 2-3 year service
I did search the forum to find an answer but no success
Where does everyone get their Alde flush service done?
I realize there are 3 options it seems
1) closest dealer
2) Truma FL, IN, AZ, TX
3) DYI
I priced the glycol and the DYI thread on building my own pump and then got a price from Truma and my dealer.
Truma and the Airstream dealers charge the same price for a 2 hour full ALDE service flush and replace as does the glycol purchased by itself and then the Y chromosome factor of thinking I can do this without fault on my own.
My deciding factors:
Truma is 5 hours away
Airstream dealer is 4 hours away
DYI no distance but the oh crap factor exists.
I obviously have no issues driving for proper service but I'd just like to see what the majority does.
Thanks!!
jeeptree2112 is offline   Reply With Quote
Old 03-02-2023, 08:27 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
We haven’t had to do ours yet. 2018 classic here but there was a fluid recall and flush in 2020 or 2021. I’ll likely just take it to a service center personally.
That Alde fluid is liquid gold and knowing my luck, I’d knock over the 5 gallon drum and have to order another one AND be without heat until then
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 03-03-2023, 04:07 PM   #3
DewTheDew's Avatar
2020 30' Classic
Frederick , Maryland
I am having the dealer do it for my 2020 (that may or may not have had the recall work done and new fluid installed) since it was in for warranty work anyway. My fear for DIY (I am naturally pessimistic/lazy) is that it seems there are about a dozen possibilities where valves are and they seemed to change the locations about every few months. I'm honestly unsure where all of them are on my 30'.
DewTheDew is offline   Reply With Quote
Old 03-18-2023, 06:10 AM   #4
2018 33' Classic
Las Vegas , Nevada
1) closest dealer
3) DYI
Thanks!!
I have an 2018 33; originally was told the fluid had to be changed every 2 years. There was a recall for 2018 and some 2019s and they replaced the fluid and was told new fluid is good for 5 years. My LAs Vegas dealer did the fluid drain and flush— they never got the air out of the system and I had to do it myself. There is a thread on here for diy, pretty straight forward and will save a lot of money and aggravation with poor dealer support.
ejs5405 is offline   Reply With Quote
Old 03-30-2023, 07:39 PM   #5
Cirrusaly's Avatar
2021 30RB Classic
Saint Augustine , Florida
Completed flush and fill and system inspection at Truma Lakeland one month ago. Good experience.
Current: 2021 Classic 30' RBT
Past: 2019 Flying Cloud 27' FBT
WBAC 9602
Instagram: Cirrusaly.Silver
Cirrusaly is offline   Reply With Quote
Old 01-14-2025, 08:48 PM   #6
69SoulShine's Avatar
Bluffton , South Carolina
Would you mind if I ask what you paid for that service?
69SoulShine is offline   Reply With Quote
Old 01-15-2025, 01:41 AM   #7
Cirrusaly's Avatar
2021 30RB Classic
Cost of service
Around $450. Included system check (LP pressure, voltage).
WBAC 9602
Old 01-16-2025, 07:12 AM   #8
Thanks we had it done at the same location last Tuesday morning and it was around $640. It didn’t take a hour.
When we had our boiler replaced their just over two years ago, they said it would be under $300. I knew it would probably be more but I did not imagine over double the price
Old 01-16-2025, 07:13 AM   #9
Great guys and Service though
Old 01-17-2025, 09:59 PM   #10
2019 30' Classic
Alexandria , Virginia
I was under the impression that the flush was an every two year undertaking. We have a 2019 and the system was flushed two years ago. I spoke to the Truma folks (very helpful) who said as long as we bleed the air and keep the fluid at a sufficient level, it should be five years between flushes. Sounds good to me!
Sometimes the road less traveled is less traveled for a reason…
LilBird is offline   Reply With Quote
Old 01-18-2025, 06:51 AM   #11
I had recently read about this five year schedule also. I asked them about this at the service and they said they still suggested every two years but could not give me a good reason why. I think the next service will be more along the five year schedule.
Also may look into buying the pump hose and bucket myself. Several years back it was mentioned here on Airform’s that everything except the fluid would cost you around 200 bucks if I remember correctly.
When they did the service, they never looked at the Aldi unit itself. They just flushed the system from the holding tank turned it on heated it up checked the fluid and that was that.
Old 01-18-2025, 09:19 AM   #12
2022 33' Classic
Chesapeake , Virginia
We had our Alde service done at the two year point, at Truma/Alde in Elkhart. A bit pricey, but we were on the way to Alaska. The glycol likely could have gone another year. Techs did not have any issues.
Name:	Old Alde glycol.jpg
BGClassic is offline   Reply With Quote
Alde overheat red hot and empty alde tank Alreddawg19 General Repair Forum 2 10-14-2021 09:19 PM
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 07:36 AM
Alde - Service needed Cejones4210 2016 - Current Classic (all lengths) 13 02-24-2020 10:21 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 08:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 07:09 AM
