01-24-2020, 10:22 AM
2015 28' Flying Cloud
2018 33' Classic
Cumming
, Georgia
Airstream letter about new Alde glycol
My Classic has the original Alde system. Got a letter from Airstream today directing me to take our 2018 Classic 33 to our dealer to replace/upgrade to a new type of Glycol. Anyone know more about what’s really going on?
01-24-2020, 10:32 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I’m sure it has something to do with Cancer and the State of California.....
01-24-2020, 10:58 AM
2018 30' Classic
Thousand Oaks
I haven’t heard anything about it. If it’s free then go ahead and do it. It also may be a letter from your dealer reminding you that the two year recommended replacement of Alde fluid is now.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
01-24-2020, 11:02 AM
Sag Harbor
, New York
Have they offered to pay your total travel expenses in full?
01-24-2020, 11:15 AM
2019 30' Classic
Sunnyvale
I have a 2019 with yellow fluid. When I added glycol (from JC) the other day, it was blue. So what is the new glycol?
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
01-24-2020, 12:49 PM
Riveted
2018 33' Classic
Charleston
, West Virginia
DeltaRon
Best to call JC for the “scoop”. I made an appointment to have it done at JC. Also includes a additional ground wire to the Alde boiler which is suppose to help with galvanic corrosion caused by the fluid moving through the system. It is a new fluid but not sure on extended replacement life or if it will still be two year replacement. Kevin at JC wasn’t sure and said they would have answer when I brought it in in a couple of months. Kudos to them for improving or trying to correct an issue. Replacing fluid every two years at $$$ doesn’t sound very desirable.
01-24-2020, 01:51 PM
2018 25' International
Slidell
, Louisiana
Alde has switch to antifreze with glycerine rather than glycol and a OAT with compatible silicate based additive for corrosion protection it is an improvement over some of the previous formulations in that the anti-corrosion properties break down about half as fast in aluminum systems so it does not need to be changed but every 5 years and the silicates also work better with aluminum components. Some claim the glycerine is more environmentally friendly but that presumes Carbon Dioxide (Plant Food) is harmful to the environment which is a bogus claim.
Older soldered brass systems should not use the glycerine / silicate / OAT formulations, they should stick with G11 or G12 glycol IAT formulations.
01-24-2020, 02:17 PM
2019 30' Classic
Sunnyvale
I just finished talking to Cory at JC and my 2019 is affected. He did say there is a new formulation and that it will prevent corrosion from happening.
The system has to be flushed by your dealer and the new fluid added. All for free.
Tom & Doty
01-24-2020, 02:25 PM
Slidell
, Louisiana
You should generally not mix different colors of antifreeze as they are often not the same formulation and will dramatically reduce the anti corrosion properties. Yellow and oranges and magenta formulations are usually HOAT, blues reds, and ,dark greens are generally OAT. So in your case it could be worse but.... You have likely lost much of the anti corrosion properties so you should flush the system within the next 6-9 months. Try never to mix the bright green IAT with any of the other colors.
01-24-2020, 07:43 PM
2018 30' Classic
Thousand Oaks
Awesome. I have a JC appointment in April, I’ll check to see if we are impacted (wouldn’t be surprised being an 18) and try and get this added to the week.
BigSxyWhtGuy
01-25-2020, 10:22 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I have not seen a letter (yet). Since my 2017 *should* have the "bad old stuff" in it, I'd guess I should be watching my mail box .....
Do they provide free beer while they are changing out the Alde fluid ?
01-25-2020, 12:00 PM
The Panhandle
, Idaho
No Letter Here Either
2017 Classic 30' here as well. We also have not received this letter regarding changing out the fluid. And wouldn't you know it? Had it into the local dealer for some warranty items prior to putting it away for the winter and one thing they did was the prescribed 2 year replacement of the original fluid. Looks like when it comes out of winter storage it may be going back to the dealer for this work if we are also affected.
Hoagie '59
Hoagette '57
Rika - The Aussie Whirlwind
01-25-2020, 12:39 PM
Slidell
, Louisiana
Just take a quick look at the fluid color, if it is magenta, orange or yellow you are likely good as is. If it is blue, red or dark green you should ask them to redo it.
01-25-2020, 05:01 PM
2018 30' Classic
Williamsburg
, VA
I have a 2018 with the blue color fluid. I checked the pH level the other day and it was 9 so I'm good to go for now. However if I do receive a letter for a free replacement I'll take them up on it.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
01-26-2020, 03:08 AM
2018 30' Classic
New York
, New York
We have an appointment scheduled in April as well. We will add this to the list. When are you there?
01-26-2020, 04:44 AM
2018 30' Classic
Cumberland
, Maryland
Wee Doggies!
01-26-2020, 06:06 AM
2018 30' Classic
Thousand Oaks
April 6th. Last of our warranty work getting done before we head to Alaska. Dropping the trailer off at JC and we rented a cabin on a near by lake to hang out at.
BigSxyWhtGuy
01-26-2020, 07:56 PM
Bluffton
, South Carolina
No letter either and following.
01-27-2020, 03:09 AM
2018 33' Classic
Cumming
, Georgia
Alde glycol
My dealer (Southland in Atlanta) is aware of change. Glycol has to be drained and replaced with a less corrosive fluid. Also they had to add some grounding wires to system.
01-27-2020, 06:14 PM
2019 - 33' Classic
2019 33' Classic
Grand Junction
Following - Thank you!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
