Old 10-05-2020, 07:21 PM   #1
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Actual Fuse locations in the 2018 Classic?
HI all,
My main lights in the front part of my classic aren't turning on.
None of the breakers, (or those cure little white button things), are thrown.
the breaker panels say it's #4 with a 5 amp. But where are those fuses?
Any help?
DAve
davcarv is offline   Reply With Quote
Old 10-06-2020, 01:30 AM   #2
Long Island , New York
Is your AS owner's manual any help on this, perhaps in an appendix in the back?
With shore power disconnected, have you checked all the wire connections in the breaker panel? They often jiggle loose over time:
https://www.google.com/search?q=circ...=airforums.com
Good luck,
Peter
Old 10-06-2020, 01:51 PM   #3
steverino's Avatar
2018 30' Classic
Ivins , Utah
Images: 8
Originally Posted by davcarv View Post
HI all,
Any help?
DAve
To my knowledge all the 12v breakers are on the G6 panel behind the false wood panels below the clothes locker. However there is more 12v circuitry and junctions in an aluminum box under the center section of the sofa.
Good luck
Steve
2018 Classic 30 RBQ
steverino is offline   Reply With Quote
Old 10-07-2020, 06:14 PM   #4
2018 33' Classic
Smyrna , Georgia
just went through something similar not with lights but with the table motor on my 2018 33 classic. I was told there are no fuses, there are only breakers by the AS dealer here in Atlanta. I know I pulled just about everything looking for a breaker panel.....good luck and if you happen to find a fuse panel I would be very interested in where it might be located.
skniseley is offline   Reply With Quote
Old 10-08-2020, 04:56 AM   #5
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
HI all,
Any help?
DAve
The fuses are on the right side of the same panel as the circuit breakers. The breakers are only for the 120v side of the trailers. The 12v is all fuses. These are mini-fuses like you find in modern cars. You will need a puller to remove them. Unfortunately, they are not labeled, although the amperage is color-coded. https://www.onallcylinders.com/2017/...r-truck-fuses/ Five amp is light brown.
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
Froglips is offline   Reply With Quote
Old 10-08-2020, 05:01 AM   #6
Doesn't the owner's manual have an illustration of those fuses, perhaps in an appendix in the back?
https://www.airstream.com/wp-content...manual-125.pdf
See p. 8-16 [PDF p. 82/98]
Peter
Old 10-08-2020, 05:10 AM   #7
Dave, are you following this discussion?
Peter
Old 10-08-2020, 06:50 AM   #8
2018 30' Classic
Williamsburg , VA
I have also looked and not found fuses. The owner's manual also does not list any fuses. I believe the 2018 Classicss only have breakers.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 10-09-2020, 11:06 AM   #9
2018 33' Classic
Smyrna , Georgia
my breaker panel has the location for the fuse panel but is blank, was told there are only the breakers with the firefly system
Old 10-10-2020, 06:41 PM   #10
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Hi ORTA15,
Thanks for replying to my post.
To answer the question in your reply, ... the owners manual refers to a 12v distribution Fuse block but not it's location.
So No luck.
I sent a message to AS support. ... 2nd attempt
Old 10-10-2020, 06:45 PM   #11
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Hi Steve and Thank you for replying to my post.
So question for ya.
On my 2018 There are two false panels under the wardrobe. 1. is a panel that has breakers and the other 2. is a panel with a bunch of round buttons.
What I don't see is a Fuse block.
What I'm wondering is where this 12v fuse block is on the 2018 Classic.
Old 10-10-2020, 06:47 PM   #12
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Hey man, you're in Atlanta too?
I'm in the Johns creek area.
We should get together and compare notes.
Friend me.
Old 10-10-2020, 06:51 PM   #13
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Thanks for replying to my post FrogLips, ...
if you send me an image of the elusive Fuse Block I'll buy you a Costco Lunch.
Old 10-10-2020, 06:54 PM   #14
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
(I attached an image of my breaker panel).
Note no fuses.
Name:	2018 Airstream Classic Breaker Panel.jpg
Old 10-10-2020, 06:55 PM   #15
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Noppers.
Old 10-10-2020, 06:56 PM   #16
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
I'm thinking there aren't any fuses, ...
I'm beginning to think that this FireFly System isn't that good
Old 10-10-2020, 06:58 PM   #17
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
HI Peter, ... I am. I've just not had the opportunity to reply until this eve.
Old 10-10-2020, 07:00 PM   #18
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
I believer your right.
I'm worried this issue isn't resolvable via DIY and I'm going to have to go the stearlership
Old 10-10-2020, 07:04 PM   #19
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
BTW Peter, ... This eve I was able to research my owners manual and 5-10 it refers to a 12v Fuse panel but not it's location.
My breaker panel has what looks like it should house a fuse block but it's blank, (see the image that I attached to a reply to FrogLips.
Old 10-10-2020, 07:06 PM   #20
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
I think your right and the owners manual is faulty
Check valve locations for 2018 FB Sport lilboomer Fresh Water Systems 0 10-04-2020 09:33 AM
Actual carrying capacity of 2019 Classic 33 Jhess 2016 - Current Classic (all lengths) 24 01-26-2019 09:06 AM
1992 36" tag Land Yacht Fuse Locations. ARK Land Yacht/Legacy Motorhomes 2 05-07-2018 01:59 PM
2018 Flying Cloud 25FBT vs 27FBT MSRP vs actual Rainbird Trailer Values 16 03-11-2018 09:27 AM
Fuse box/panel locations 97sx Classic Motorhomes 6 05-18-2011 10:59 AM
