10-05-2020, 07:21 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
Actual Fuse locations in the 2018 Classic?
HI all,
My main lights in the front part of my classic aren't turning on.
None of the breakers, (or those cure little white button things), are thrown.
the breaker panels say it's #4 with a 5 amp. But where are those fuses?
Any help?
DAve
10-06-2020, 01:30 AM
Sag Harbor
, New York
Is your AS owner's manual any help on this, perhaps in an appendix in the back?
With shore power disconnected, have you checked all the wire connections in the breaker panel? They often jiggle loose over time:
https://www.google.com/search?q=circ...=airforums.com
Good luck,
10-06-2020, 01:51 PM
2018 30' Classic
Ivins
, Utah
Originally Posted by davcarv
HI all,
Any help?
DAve
To my knowledge all the 12v breakers are on the G6 panel behind the false wood panels below the clothes locker. However there is more 12v circuitry and junctions in an aluminum box under the center section of the sofa.
Good luck
Steve
2018 Classic 30 RBQ
10-07-2020, 06:14 PM
2018 33' Classic
Smyrna
, Georgia
just went through something similar not with lights but with the table motor on my 2018 33 classic. I was told there are no fuses, there are only breakers by the AS dealer here in Atlanta. I know I pulled just about everything looking for a breaker panel.....good luck and if you happen to find a fuse panel I would be very interested in where it might be located.
10-08-2020, 04:56 AM
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte
HI all,
Any help?
DAve
The fuses are on the right side of the same panel as the circuit breakers. The breakers are only for the 120v side of the trailers. The 12v is all fuses. These are mini-fuses like you find in modern cars. You will need a puller to remove them. Unfortunately, they are not labeled, although the amperage is color-coded. https://www.onallcylinders.com/2017/...r-truck-fuses/ Five amp is light brown.
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
10-08-2020, 05:01 AM
Sag Harbor
, New York
Doesn't the owner's manual have an illustration of those fuses, perhaps in an appendix in the back?
https://www.airstream.com/wp-content...manual-125.pdf
See p. 8-16 [PDF p. 82/98]
10-08-2020, 05:10 AM
Sag Harbor
, New York
Dave, are you following this discussion?
10-08-2020, 06:50 AM
2018 30' Classic
Williamsburg
, VA
I have also looked and not found fuses. The owner's manual also does not list any fuses. I believe the 2018 Classicss only have breakers.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
10-09-2020, 11:06 AM
2018 33' Classic
Smyrna
, Georgia
my breaker panel has the location for the fuse panel but is blank, was told there are only the breakers with the firefly system
10-10-2020, 06:41 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
Hi ORTA15,
Thanks for replying to my post.
To answer the question in your reply, ... the owners manual refers to a 12v distribution Fuse block but not it's location.
So No luck.
I sent a message to AS support. ... 2nd attempt
10-10-2020, 06:45 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
Hi Steve and Thank you for replying to my post.
So question for ya.
On my 2018 There are two false panels under the wardrobe. 1. is a panel that has breakers and the other 2. is a panel with a bunch of round buttons.
What I don't see is a Fuse block.
What I'm wondering is where this 12v fuse block is on the 2018 Classic.
10-10-2020, 06:47 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
Hey man, you're in Atlanta too?
I'm in the Johns creek area.
We should get together and compare notes.
Friend me.
10-10-2020, 06:51 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
Thanks for replying to my post FrogLips, ...
if you send me an image of the elusive Fuse Block I'll buy you a Costco Lunch.
10-10-2020, 06:54 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
(I attached an image of my breaker panel).
Note no fuses.
10-10-2020, 06:55 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
Noppers.
10-10-2020, 06:56 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
I'm thinking there aren't any fuses, ...
I'm beginning to think that this FireFly System isn't that good
10-10-2020, 06:58 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
HI Peter, ... I am. I've just not had the opportunity to reply until this eve.
10-10-2020, 07:00 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
I believer your right.
I'm worried this issue isn't resolvable via DIY and I'm going to have to go the stearlership
10-10-2020, 07:04 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
BTW Peter, ... This eve I was able to research my owners manual and 5-10 it refers to a 12v Fuse panel but not it's location.
My breaker panel has what looks like it should house a fuse block but it's blank, (see the image that I attached to a reply to FrogLips.
10-10-2020, 07:06 PM
1989 29' Excella
2018 30' Classic
Cumming
, Georgia
I think your right and the owners manual is faulty
