Old 04-01-2018, 03:37 PM   #1
2018 30' Classic
Traverse City , Michigan
AC won’t turn off
Help. Easter Sunday and we’re in FL. Oolong off so opened up BUT the AC won’t shut off. What do we do?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 04-01-2018, 04:06 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I'm not sure what exactly "Oolong" is, but as far as the air conditioners go, did somebody accidentally turn the emergency a/c switches on?
Old 04-01-2018, 04:07 PM   #3
2018 30' Classic
FYI. It’s a 2018 Classic.
Manual says there’s an override switch but husband is on the roof and see no switch.
2018 30’ Classic
Old 04-01-2018, 04:07 PM   #4
Reads a lot
Titusville , Florida
I had the same issue with my Classic right after purchase. Until you can get it repaired or replaced the easiest thing to do is manually turn off the unit. In my case it was the rear unit that was having the problem. It wouldn’t shut off no matter what temperature I had it set at. I turned that unit off and just used the front AC. Not to fear, it should be covered under your warranty and will not effect the other AC unit.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 04-01-2018, 04:08 PM   #5
2018 30' Classic
Overlandet don’t even know where that is.
2018 30’ Classic
Old 04-01-2018, 04:09 PM   #6
2018 30' Classic
Did turn it off at the computer board where we turn it on. Still running even though we shut it off.
2018 30’ Classic
Old 04-01-2018, 04:14 PM   #7
2018 30' Classic
Overlander, sorry, should have said cooling off.
2018 30’ Classic
Old 04-01-2018, 04:15 PM   #8
1993 21' Sovereign
On your Classic, there are two rocker switches located in the overhead compartment where the Blu Ray player is. Both should be "off". If they are, make sure both air conditioners are "off" in the firefly touch screen. If everything is off, last resort is to locate the two breakers for the air conditioners, and switch those off.
Old 04-01-2018, 04:18 PM   #9
Reads a lot
Have you located the dometic control board? It may be under your kitchen sink? Some of the ‘18s had everything going through the Firefly but there might still be a manually controlled panel somewhere inside.
Lauri
Old 04-01-2018, 05:49 PM   #10
2018 30' Classic
Finally found the reset switch and the breaker. (Breakers weren’t labeled. ). At least it’s off. Now we can get it repaired some place.
Thanks for everyone’s help.
2018 30’ Classic
Old 04-02-2018, 10:57 AM   #11
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi SMKovalchik,
We're very sorry to learn about the issue with your AC that you described in your 2018 30' Classic. Please send me a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
We look forward to helping you get this resolved.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 04-03-2018, 04:20 AM   #12
2018 30' Classic
Spoke with Airstream yesterday. The customer service representative I spoke to had just, a few minutes prior to that, talked with Firefly about that very issue.
For others checking this thread the solution is turn the battery switch to off and unplug the shore power or flip the main breaker. Let it sit for 2-3 minutes then flip the battery back on and plug the unit in. It resets the Firefly system and should rectify the problem. (In our case flipping the AC breaker took care of the problem so far.)
2018 30’ Classic
Old 04-26-2018, 11:47 AM   #13
2018 30' Classic
Jacksonville , Florida
You mean, "reboot" it, with a "hard shut down" ?
We had a similar problem. The front AC fan continued to run. That little ghost "Not Me" from the comic strip Family Circle put the fan in the manual mode instead of "Auto".
Overstreet is offline   Reply With Quote
Old 04-26-2018, 07:05 PM   #14
Cardinal283's Avatar
Dallas , Texas
Just move to Texas. You won't ever want to turn it off.
Cardinal283 is offline   Reply With Quote
Old 04-21-2019, 05:52 PM   #15
Camping Dutchman
2018 33' Classic
Manchester center , Vermont
Excellent. Had the same problem and it fixed it. Love this forum.
Menno is offline   Reply With Quote
Old 04-21-2019, 06:53 PM   #16
2019 27' Globetrotter
Missouri Valley , Iowa
I had a similar problem with our 2017 26U. The fan speed control needed to be set on automatic on the thermostat. That let us run the furnace when the temps cooled off without having the AC running.
Dan
Farmer Dan is offline   Reply With Quote
Old 04-21-2019, 07:34 PM   #17
Long Island , New York
Similar to hard reboots for phones and tablets, and manual restarts for computers, the above should be standard practice whenever one of our devices malfunctions.
Dometic also has a thermostat hard reboot procedure, spelled out in their manual, which often solves lots of problems.
Thanks for the update.
Peter
OTRA15 is online now   Reply With Quote
Old 09-12-2020, 12:14 PM   #18
teresamarie's Avatar
2017 25' International
, Nevada
Thumbs up Worked!
I had the same problem with my 2017 Serenity today - this solution worked for me! Thank you!!!
teresamarie is offline   Reply With Quote
Old 09-12-2020, 01:10 PM   #19
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Firefly operating system by Microsoft?
My refridgerator won't turn off! politicurl Electrical - Systems, Generators, Batteries & Solar 2 10-21-2011 06:26 PM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 07:41 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
won't turn off! AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-22-2009 09:52 AM
Fridge Fan won't turn OFF clancy_boy Refrigerators 7 09-04-2007 08:55 PM
