33FB Bedroom Door Catch Fix
I got our new 33FB twin classic, and one of the doors to the bedroom would not catch when inside the door pocket. This meant that when driving it would open and close.
After a little exploring I discovered about 1/2 the way up the door inside the pocket was magnet on a metal bracket, but the bracket was bent back about 30 degrees.
I was able to bend it back forward by pulling the door all the way out, then with a flashlight and a wire hanger reach between the door and wall, loop the hanger around the magnet bracket, and pull it forward.
The door now catches and holds like it is suppose to.
Photo is looking through the door crack showing magnet on metal bracket.
I’ve seen other people complain about the bedroom doors not catching and holding open and this is likely the problem.
