Old 09-17-2024, 08:51 PM   #1
2019 27' Globetrotter
Marthasville , Missouri
33 bathroom caulk
Quick question for those that have re-caulked the shower wall with the trailer side: what caulk did you use that is flexible/stretchy enough to withstand the inevitable flex between the wall and side while towing?
2020 Classic 33FBQ
2019 Globetrotter 27 FBQ
2020 RAM 3500 Laramie Longhorn Dually HO/AISIN
ProPride hitch
Dutch Air is offline   Reply With Quote
Old 09-18-2024, 09:22 AM   #2
2022 33' Classic
Chesapeake , Virginia
I just used the white silicone bath caulk found at HD. I had a few breaks in the runs, and so far, so good.
BGClassic is offline   Reply With Quote
Old 09-18-2024, 09:48 AM   #3
2002 19' Bambi
Lafayette , California
After trying various caulks for our shower stall, I finally ended up using Sikaflex. No, it isn't ideal because the surface does not become super smooth and dry feeling, but the stuff has not broken loose, cracked, or leaked in the years it has been in place.
Tim
Tim A. is offline   Reply With Quote
Old 09-18-2024, 05:03 PM   #4
Thank you for the response, I’ll give the silaflex a try
2020 Classic 33FBQ
ProPride hitch
Old 09-19-2024, 09:43 AM   #5
Waynesville , Georgia
We used flexible grout from Flextile.com as the adhesive for small hex tile in the shower and to caulk seams in the bathroom and kitchen.. Great stuff.
1963 Overlander “Meraki”
ChristyB56 is offline   Reply With Quote
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
caulk removal Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 10-17-2002 08:56 AM
