06-30-2018, 04:36 PM
2018 27' International
Southeastern MI
, Michigan
2018 Serenity 27’ no 110 power
Checked the obvious: outlet has power, tried it on generator, etc. I have single AC and there are two power ports on outside; left side and front by propane tanks and I’ve tried both. Checked breakers and fuses too. Any ideas?
I’ve heard of transfer switch problems and searched here but couldn’t actually find any transfer switch on mine. There’s a 12V power panel and an inverter under the front bed but nothing else.
Noticed the problem when I tried to run the AC (at home thankfully before a trip). Advice appreciated!
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
06-30-2018, 04:43 PM
2017 28' International
Jim Falls
, Wisconsin
06-30-2018, 04:49 PM
Southeastern MI
, Michigan
Yep, 12v stuff, and inverter, works.
Michelin 16” tires
Hensley Arrow hitch
06-30-2018, 05:11 PM
Southeastern MI
, Michigan
Putting surge protector in bypass mode restored power.
Michelin 16” tires
Hensley Arrow hitch
06-30-2018, 06:00 PM
Jim Falls
, Wisconsin
That’s odd. Could be something wrong with your surge protector. That’s the weak link then. I assume it is built in.
06-30-2018, 06:05 PM
2007 22' International CCD
Corona
Or something wrong with input power. Check surge protector error codes.
06-30-2018, 06:45 PM
Southeastern MI
, Michigan
Dealer installed it. I think the problem may be my garage outlet (test light shows open ground). Running on generator to cool down the AS (was 104 degrees inside the unit and 96 outside today).
Michelin 16” tires
Hensley Arrow hitch
06-30-2018, 07:07 PM
Jim Falls
, Wisconsin
So then your surge protector was working! If you have an EMS system like I do that’s what it’s suppose to do. It’s just odd if you have used the same outlet before and the EMS didn’t shut it down.
06-30-2018, 07:17 PM
Southeastern MI
, Michigan
I had a whole house generator installed and something may have happened to that line when the work was done. I’ll get it checked out.
Michelin 16” tires
Hensley Arrow hitch
07-02-2018, 10:13 AM
2015 27' FB International
Seminole
Was it a potable generator that you used. If so it needs to have a grounding plug, bonding the neutral to the grounded conductor. If not, your trailer will see a open ground.
07-05-2018, 12:24 PM
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
All generators come with ( or should come with) the neutral floating relative to the chassis ground. That works fine in some cases and is relatively easy to correct in the cases where it does not. In a home, the neutral and ground should be bonded at the main panel ( = generator should work ok). In an RV the expectation is that the bond is at the shore power pole ( = generator needs some help ). With anything like this one can never say 100% how anything has been done. In most cases, the generator will need an adapter that bonds ground and neutral to properly feed the trailer. If that's not present all sorts of odd (and possibly very dangerous) things can happen.
Not quite sure what this is doing in the "Classic" sub-forum ...
