RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-21-2020, 11:13 AM   #1
fiddyl's Avatar
pomfret , Connecticut
Window Rubber Seals Stick to Glass
The window rubber seals have been sticking terribly to the glass. We always have to go outside to open them! Actually pry them open with a heavy guitar pick. 1mm for you guitar players!! Anyone use anything to lube them or keep them rubbery, slippery, or something so they don't stick to the glass?
fiddyl is offline   Reply With Quote
Old 11-21-2020, 11:14 AM   #2
fiddyl's Avatar
More info, we are in CT, the Temps are not that hot here. It is all the windows not just the ones in the sun. Would Vaseline ruin the rubber? Thinking about trying that.
Old 11-21-2020, 11:29 AM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
My 2013 AS owner's manual says
"Apply 303 Aerospace Protectant to the window
gasket. To apply, spray/pour 303 onto a soft rag
or sponge and apply a generous coating directly
to the gasket."
I used 303 for several years, and it doesn't seem to help that much. Someone on the forum recommended Gummi Pfledge, so I tried that. It seems about the same.
Other recommendations have included silicone spray and powdery treatments.
Extra tip: Clean both the gasket and the window surface that meets the gasket.
SSquared is offline   Reply With Quote
Old 11-21-2020, 11:31 AM   #4
s1000pre's Avatar
2020 25' International
minneapolis , Minnesota
We tried the 303 Protectant and it failed. Just Find peace with it!!! The best part of an Airstream is all of the windows which do eventually open!!! Make it part of your arrival setup. Unlock all windows, then from the outside...walk around and run a credit card up/down both sides and across the bottom of all the windows to release. You should only need to do this once. ...If you do them all at once, it only takes 3 or 4 minutes!
s1000pre is offline   Reply With Quote
Old 11-21-2020, 11:37 AM   #5
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I use a product made by Wurth. Wurth Rubber Care, is used on the airstream window rubber, entry door rubber, outside compartment doors, and all of the rubber gaskets on my vehicles. Works well, and extends the life of the rubber.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 11-21-2020, 11:41 AM   #6
fiddyl's Avatar
Are you saying to unlock, run the credit card around, but not raise them? That way they are ready to go when you want to open them during your stay? ...avoiding the continual frustration of dealing with one window as needed. Seems like a better plan than we have now.
Also, do you think Vaseline is safe to use? I guess I won't even bother buy the 303 Protectant. My husband thought Armour All might be of some help.
Old 11-21-2020, 11:42 AM   #7
fiddyl's Avatar
Ooooh. Thank you. We will try that!
Old 11-21-2020, 11:43 AM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Dielectric grease works very well. It has been used on automotive weather seals for many years. Just don't use too much.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-21-2020, 11:45 AM   #9
fiddyl's Avatar
No to Vaseline. I just researched that and it deteriorates it.
Old 11-21-2020, 11:53 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Larry
X2
Been using it for years.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 11-21-2020, 12:40 PM   #11
s1000pre's Avatar
Yes...this is only a preparation before opening. I have opened them from the outside while doing the credit card thing. All you do is lift the window and pop the supports in place from the outside...if you choose to do so! Otherwise, as I run the credit card around from the outside. I use my other hand and slightly pull on the bottom edge. Once it releases you are good to go... Most of the time you won't make it all the way around before the thickness of the credit card pops it open. I didn't attempt vaseline, it just adds other concerns...
Old 11-21-2020, 01:26 PM   #12
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Vaseline is bad news for rubber (destructive). Dielectric Grease will be pretty messy (it's like vaseline, but shouldn't degrade the rubber). You can buy silicon spray at Lowes or Home Depot. It's cheap and works pretty well for what you're talking about, plus you can use it to lubricate locks and hinges. Spray it on your finger (or in a small container to dip your finger into), and then run your finger over the rubber seal to minimize your mess.
One thing that isn't getting mentioned so far is to *clean* the seals first to remove whatever residue/decomp that is making them stick in the first place.
kidjedi is offline   Reply With Quote
Old 11-21-2020, 01:37 PM   #13
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
This stuff would be good to try. Goes on very thin and dries up. Leaves a silicon film on surfaces. It smells pretty good as well?
http://www.jigaloo.ca/lubricant/1-jig-a-loo.html
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 11-21-2020, 05:17 PM   #14
2016 30' International
redondo beach , California
While your at it make sure the emergency window can be opened!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 11-21-2020, 05:55 PM   #15
1966 22' Safari
Fredericksburg , Texas
Iím with kidjedi. 3 in 1 rv care sprays have rv rubber gasket conditioner among other products like metal track spray for RVs. We use it regularly and has worked well. The box stores have it. Good luck
Bubba L is online now   Reply With Quote
Old 11-21-2020, 09:12 PM   #16
2020 25' Flying Cloud
Chula Vista , California
I leave an old gift card next to the door. Wife unlocks the windows, I run the card as I'm setting up the outside. With the gift card I don't lose the CC or possibly mess up the magnetic stripe
Oreg52 is offline   Reply With Quote
Old 11-21-2020, 09:27 PM   #17
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Both
303 Aerospace Protectant and
Gummi Pfledge
are good products to keep the rubber from drying out
waninae39 is offline   Reply With Quote
Old 11-21-2020, 09:56 PM   #18
2013 30' Flying Cloud
Kingwood , Texas
I use the 303 Protectant monthly and have installed the Window Poppers on all the windows that open.
DoubleR is offline   Reply With Quote
Old 11-22-2020, 07:08 AM   #19
2019 30' International
Pennsylvania , Pennsylvania
I use.....nothing.
Clean the inner glass edge, where it contact the rubber gasket, of all stuck on debris and hazing.
Clean the rubber gasket well.
Done.
Open with credit card when needed.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-22-2020, 08:54 AM   #20
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I use window poppers as well.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
69SoulShine
storage door rubber seals ronboy General Repair Forum 1 02-18-2016 01:15 PM
Corning glass contour and the rubber seal KennewickMan Windows & Screens 17 07-08-2014 07:13 AM
Side window glass rubber trim '09 Interstate Wisconsinden Sprinter and B-van Forum 1 10-24-2012 09:10 AM
Front window rock guard rubber... are they seals? Gator113 Windows & Screens 7 05-30-2010 03:52 PM
What to use to keep window seals/rubber soft. Safari-Rick Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-27-2006 07:24 AM
