11-29-2020, 12:24 PM
#61
2016 27' International
Sherwood Park
, Alberta
Originally Posted by PB_NB
Funny, the ad says "no scent". I think it smells pretty good as well.
11-29-2020, 12:37 PM
#62
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah
, NSW Australia
Originally Posted by mythbuster88
While your at it make sure the emergency window can be opened!
You beat me to it. Almost all of the regular swing-out escape windows are so stuck that they are impossible to open in good conditions let alone in an emergency.
Try it.
11-30-2020, 03:43 PM
#63
2010 25' FB International
Livermore
Use a wax-based teflon-impregnated dry lubricant. We apply this with a rag and it lasts about 2 years, and no film gets onto the glass:
https://www.amazon.com/DuPont-Chain-...dp/B008S7OG52/
01-20-2021, 11:15 PM
#64
2017 25' International
Woodinville
Someone also told me olive oil is the only thing that works. I have not tried it.
01-21-2021, 09:17 AM
#65
Freedom
2023 30' Classic
Dallas
, TX
We bought this tool and it has worked great when they stick. I use the thinner end and it is quick and easy.
To treat the rubber I've been using Slide Lub. I just applied it before our last trip and all the windows opened up easily. Time will tell how effective it is once we go on one of our extended summer trips.
2023 30 Foot Classic
2022 Ram 3500 Dually
01-21-2021, 01:28 PM
#66
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by davetoregon
I used the 303 spray wiped on the rubber with a rag or paper towel. Once a season seems to work for us. Once a month would be better.
To pry a stuck window I have this kit in the trailer
PITTSBURGH AUTOMOTIVE
Nylon Pry Bar Installer Kit, 4 Pc.
from Harbor Freight. Keys, screwdrivers, credit cards will work but be careful of tearing the rubber.
Try this.👍
01-21-2021, 03:42 PM
#68
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Armorall ...
01-21-2021, 06:21 PM
#69
2017 25' Flying Cloud
Fayetteville
, Arkansas
Protectant, Talcum powder and window poppers.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
01-21-2021, 08:18 PM
#70
2019 19' Flying Cloud
Canyon Country
I just read the Airstream Flying Cloud manual and it tells us what to do in case it happens. There is a preventive maintenance for that, also. 303 Aerospace Protectant is what Airstream recommend.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
01-22-2021, 06:42 AM
#71
Arroyo Grande
Urge that you don't use any lubricant - such as gasoline or similar - as it will only collect dirt. And, some solvents will damage the rubber. Clean the seals and the glass, and install a set of WindowPoppers - you'll never have to go outside the trailer to open your windows again! You can get them from www.seeyoudowntheroad.com
01-22-2021, 07:08 AM
#72
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Why buy something when proper maintenance will assure proper function.
Plus, when they break you'll just have a hole in the window frame or dried weatherstrip stuck to the window from forced opening.
"Cloudsplitter" 18yrs and sticking window free.
01-22-2021, 07:36 AM
#73
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Over the years, I have had two Airstreams with the top-hinged windows. I have simply drilled a 1/4' hole in bottom of the window screen frame. Then I use a piece of wooden dowel to push the window glass free from the rubber weather strip. It works from the inside (you can do this without getting dressed to go outside) and it does not cost anything.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
01-22-2021, 07:30 PM
#74
Fayetteville
, Arkansas
[emoji631]
Because like many things we buy to improve our experiences with our trailer, window poppers just work. Never had a window popper break but have had windows stick even with “proper maintenance.”
FishByFly
2023 F150 XLT
01-23-2021, 04:56 AM
#75
2004 30' Classic Slideout
Fenton
, Missouri
Interesting ideas. When my trailer was new, I used to slightly dampen a small area of a paper towel with silicone spray. I then wiped down each window gasket and allowed it to dry. I’d did this about twice a year when I noticed the windows just beginning to slightly show some adhesion to the gaskets. Over the years the tendency of the windows diminished and I think the gaskets get a fine coating of dust which stops then from sticking. I think it’s been at least 10 years or so since I’ve had to do this.
My Classic has been stored inside for 15 of its 17 years of life. Maybe not sitting outside has also provided a positive effect. 303 is a good product and has no petroleum components that some other products use.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
01-23-2021, 07:52 AM
#76
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Or maybe, your 'proper' is not the same as my 'proper'.
Sweet Streams...
