Originally Posted by Captain Hank
That is the emergency kit for your Relax Awning. Save them and keep them in place where you know here they are. You will need these to manually retract your awning if it fails to close electrically. This is the only way to close your awning so you can travel if it fails. You should also read your manual from Zip Dee to know how to use these tools.
That's exactly what these are.
One of the hex head fittings at the top of your picture goes in the flexible shaft driver below it, and is used with a drill to manually retract or extend the awning arms. There is a "scribe" in the arm that shows the position to retract the arm to. You have to do this on each side. At the bottom of the main arm is the hex head nut to engage the fitting in.
The plastic tool that someone said looks like an antenna is used to make adjustments for the extent the awning goes out. I believe you use it to adjust small pots on the circuit board. Don't know where your controller board is in the 25 footer but ours is beneath the galley sink against the wall of the trailer.
The bundle of wire with the alligator clips is used to hook up to the motor that drives the shaft the awning rolls up on. The motor is on the right side of the awning. Unless you're really tall you'll need a step stool or something to get to it. You can unplug the power connector going to the motor, plug the connector on the wire harness into it, and then connect the alligator clips to your battery. It's a DC motor so hooking the clips on one way winds the awning up. Hooking them up the other way lets the awning out.
I don't know what the other fitting is in the top of your picture. My unit came with a hex shaped shaft that you can insert into the motor gears, then use a drill or a wrench to turn to manually turn the motor gears in case your motor fails. This is a
very slow process. Perhaps that fitting is for this purpose.
As Captain Hank said, hang onto these. If your motor or controller board ever fails when the awning is extended you'll need them to retract your awning, otherwise you can't tow anywhere. We initially had a lot of trouble with our awning and I had to do it several times. Not fun.
If you do have awning trouble, never, ever, ever disconnect the gas struts thinking that will help. I had to disconnect one of ours in order to free up our door which was trapped when the awning controller malfunctioned and it was a heck of a thing to get back on.
Steve
