Old 05-30-2020, 07:15 PM   #1
kbmwrs's Avatar
2016 25' International
Morgan Hill , California
Top door lock...doesn't move
I tried posting on the technical forum about doors but I'm guessing I would get a wider audience here.
Visited our 2016 25FB today at the storage lot...not close to home.
Luckily I unlocked the top lock...very stiff movement of key.
After that the key would not even move. I could lock unlock using the inside slide lock but the key...wouldn't budge...and I didn't force it.
I have done the search of this topic. I found fixes for 'escaping' when the handle doesn't work. I found fixes for the pressed on handle. I found 'add-on' door handles so not to use the pressed on version.
Is mine a common occurrence?
Has someone experienced this already? Help please...Thank YOU.
I am going to start with lube spray and then on to deconstruction. I'll add to fixes I found during my search.
kbmwrs is offline   Reply With Quote
Old 06-03-2020, 04:17 PM   #2
kbmwrs's Avatar
Thanks for ALL the help. Really appreciate it.
I took it apart. Added the handle and removed the lock. It was full of dirt which I am guessing blocked the lock mechanism. I blew it clean and added some WD40.
Old 06-16-2020, 11:57 AM   #3
2016 30' International
redondo beach , California
We use a spay can of white grease for both top and bottom locks. Just a little but 2-3 times a year. Otherwise the locks get real stiff.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 06-17-2020, 09:51 AM   #4
kbmwrs's Avatar
Does the grease collect even more dirt?
Old 06-18-2020, 10:15 PM   #5
No.
Grease is your friend.
Spray on white grease just a little.
Old 06-22-2020, 05:28 PM   #6
Powerrunner's Avatar
2019 30' International
I have had luck with spray silicone. Works great and does not build up or hold dirt or dust.
Powerrunner is offline   Reply With Quote
Old 06-22-2020, 05:44 PM   #7
2018 25' International
Slidell , Louisiana
Graphite spay is also excellent for locks and the solvent sweeps out the dirt and grime, just like the silicone solvent.
Brian
Old 06-25-2020, 12:56 AM   #8
Well the point is to lubricate the darn thing with your favorite stuff.
Top door lock...doesn't move kbmwrs Doors & Locks 2 07-07-2020 09:39 AM
Key turns but deadbolt doesn't move. alphamale49 Windows, Doors, Locks & Vents 13 07-07-2019 03:12 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Compressor runs but needle doesn't move! ericjan2 Classic Motorhomes 6 10-23-2012 04:34 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
