Old 07-12-2020, 06:18 AM   #1
Powerrunner's Avatar
2019 30' International
Tms
I am sure this is covered somewhere in this site, but i am unable to locate it. My question I have a 2019 International Serenity 30’. I would like to add a Tire Pressure Monitoring System. What do you use/recommend and why?
Powerrunner is offline   Reply With Quote
Old 07-12-2020, 06:24 AM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
We use the TST TPMS (as shown here https://store.airstreamlife.com/coll...your-airstream)
It has worked well for us and many others.
Old 07-12-2020, 06:55 AM   #3
2019 25' Flying Cloud
Houston , Texas
I have a TireMinder Trailer TPMS https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. It works well and has been reliable. My only complaint is that the display goes really dim after a short while. It says its pressure range max is 70 psi. I have been keeping the tires at 80 psi (I had bought the system for a different trailer) and it still works. It has a signal booster, which is needed. When I tried using the system without the booster, I got several dropouts. After I installed it on the underside of the battery box, I get no dropouts.
DCPAS is offline   Reply With Quote
Old 07-12-2020, 07:03 AM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Two basic ideas, external monitor that threads on to valve stem and internal transmitter.
Dill offers an internal system that monitors PSI and internal tire temp. I'm on my second Dill system and finally had to have the transmitters replaced. Drawback is tire demounting to R&R transmitter is required. Discount Tire did my replacements for cost of transmitters only as tires were purchased from them. Positives, it's all internal no valve stem concerns and temp is monitored internally. Receiver and display have several mounting options.
Either system watches out for in route issues that likely wouldn't alert driver until too late. Don't think of it as a replacement for pre trip PSI check.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 07-12-2020, 07:26 AM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Dill system for me. Works great with internal sensors. No batteries to change or sensors to loose. Just change the sensors every other tire change.
GMFL is online now   Reply With Quote
Old 07-12-2020, 08:20 AM   #6
Mollysdad's Avatar
TST with four cap sensors.
Best upgrade ever!
Old 07-12-2020, 11:20 AM   #7
Thanks, did you end up changing the valve stems out to steel stems?
Old 07-13-2020, 05:58 AM   #8
Hans627's Avatar
No. I plan to do so when I replace the tires. TST claims the partial rubber stems can be used with the 507 sensors. Many have replaced the partial rubber stems with all steel and there certainly is no harm in doing so.
One thing I've done is to remove the "security" cap and use just the sensor. Thus making it a bit lighter and smaller in diameter.
Old 07-13-2020, 06:25 AM   #9
2018 25' International
Slidell , Louisiana
To get the most out of pressure and temperature monitoring, note that the location of the temperature sensor even for the internal models are less than ideal so they will provide temperature changes but they will not provide an accurate absolute temperature while on the road. They will give you wheel temperature at best and valve stem temperature at worst.
So use the temperature to set cold tire pressure as long as the tire is shaded.
On the road watch tire pressure, note the cold tire pressure and then figure for each 10 degrees F increase in internal tire temperature pressure will rise about 2%. So if you start at 60 psi and they rise to 66 psi after driving for an hour that is 10% increase or a 50 degree increase in internal temperature.
Your tires should only gain 25-50 degrees while traveling.
Over 50 and the cold pressure is a bit low so sidewall flex is excessively heating the tire. Add a couple psi and your tires will thank you. Under 25, while great for the tire longevity, it may be a bit stiff and rattling the trailer content. It's a judgement call on what to do here.
Brian
Old 07-13-2020, 07:22 AM   #10
GCinSC2's Avatar
Brian,
A few years ago driving around Charlotte NC my monitor warned of one wheel that was warming up. It didn't go to ALARM it just showed a higher temp. Pulled over and shot the wheels with IR temp gun sure enough one was hotter than the rest. But it was the brake rotor of the disc brake system that was the heat source.
I had a good set of tools, found a parking lot, pulled the wheel and the pad was dragging on the caliper. A bit of cleaning and dab of grease took care of it. It was my fault for not cleaning the pads and caliper anchor. I did all four at the same time and continued to destination no issues.
A dragging drum brake likely would set off the same warning.
That internal temp sensor prevented a potentially more serious higher temp issue.
Advice to non TPMS owners, consider some type of TPMS.
Gary
S/OS #001
Old 07-13-2020, 08:51 AM   #11
Mollysdad's Avatar
Yes. Dill 902-W. The tires don't need to come off the rim, just one side bead pushed in to install.
Standard valve stems don't fit in our aluminum rims.
I did my own:
https://www.airforums.com/forums/f31...ml#post2382971
Old 07-13-2020, 10:21 AM   #12
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I have used the TST system for the last 4-5 years and I am very happy with them. I use the Dill 902 W valve stems as well.
thewarden is offline   Reply With Quote
Old 09-20-2020, 05:06 PM   #13
Installed the TST and love the system. I just installed the repeater. See the picture.Click image for larger version
Old 09-20-2020, 07:12 PM   #14
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
What did you wire the repeater. I’ve got one too and not happy with my wiring approach.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB - “Fly Fish Inn
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 09-20-2020, 07:22 PM   #15
Just pulled the wiring into the battery box, connected the + and - leads to the terminals. Nothing special, i am going to install a switch to power off the repeater, in the meantime I just pulled out the fuse.
Old 09-20-2020, 08:51 PM   #16
FishByFly's Avatar
I wired mine into my power jack. Installed under the Jack cover...good bit of room in there. Added a switch into the jack cover so I can switch it off. I forget to turn the switch on until I get a few miles down the road and see the tires not registering.
FishByFly
2010 F250 Lariat
Old 09-29-2020, 09:50 PM   #17
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Wired repeater to running lights - no switch necessary
I also installed the repeater on the outside of the battery box and connected the positive wire to the running lights (green wire). This way the repeater is powered only when the umbilical is connected and the running lights are on. Easy-peasy! I know it works without the repeater but the TST manual says it should be installed.
*I followed the umbilical cable into the cabin and replaced the connector with a Wago 3 conductor. Pulled a single conductor wire through the existing flexible black wire cover.
ID:	379730   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
TMS 5500 lb Trailer ELECTRIC Power Dolly RV Mover Boat drkschoi Hitches, Couplers & Balls 2 07-03-2013 09:46 PM
