Old 05-19-2021, 01:57 PM   #1
2021 27' International
The Woodlands , Texas
Service Questions
Hi Everyone, Have done my best to keep my logbook on mileage and time since i got my 2021 International 27FB and had a few questions.
Current Mileage is only 765miles
Current Time since purchase is 199 Days
According to my manual. It’s already asking to:
- Rotate tires
- Inspect wheel bearings
- inspect or replace brakes.
Do i really need to do this with this low mileage? If so, what is the best place to do this?
Thank you.
Davidmtz1981 is offline   Reply With Quote
Old 05-19-2021, 03:09 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Rotate tires? Probably not.
Inspect brakes? Based on mine, it's never to soon to inspect the brakes.
Check wheel bearings / hubs? If you are in there to look at the brakes, you can at least do a quick look at the hubs. I would not do anything crazy like pulling them.
Old 05-19-2021, 03:41 PM   #3
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
David-
Most of us (many of us? some of us?) consider bearing and brake checks to be an annual maintenance item, to be done once each yer, usually in the winter when shops are less busy.. If you have a good local Airstream dealer, they could do it, or most other RV Service centers could do it, though you should be pretty explicit about instructions for where and how to jack the unit up, as bozo's could use floor jacks in wrong location and cause damage to axles or frame or belly wrap.. As long as they are checking bearings and brakes, tire "rotation" should be a no cost item, since they'll have them all off at once and can just switch places putting them back on.. You might need to relocate TPMS system sensors, if you have a set installed.. Many Airstreams have slight "Toe in" alignment, so switching from left to right side can extend tire life slightly...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 05-19-2021, 03:45 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Maybe it's not a bad idea after the first year, even if it's low mileage, just to pick up any possible defect. After that, I base it on mileage. But since we usually do 8K miles a year it turns out to be annual. Not the case this year as we traveled only a few hundred COVID miles last season.
2019 Ford Expedition Platinum
Old 05-20-2021, 01:23 PM   #5
Thank you so much.
Everything looks decent so far and because of the very low mileage, will definitely schedule to take it for rotation and brake check at the end of the year.
Thank you so much.
Getting warranty service (or any service) at an Airstream dealer SeaLevel General Repair Forum 37 12-18-2020 05:18 PM
JC Service Terraport questions kittmaster General Repair Forum 19 07-06-2019 05:55 PM
Service A and Service B nesoutlook Sprinter and B-van Forum 17 12-14-2015 09:36 AM
Wiring Diagram/Service Manual/Questions boomerick General Repair Forum 12 11-06-2005 01:27 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 08:23 PM
