06-22-2020, 05:23 PM
2019 30' International
Austin
Refrigerator front panel falls apart - 2019 30’ Serenity
Has anyone had an issue in which the front panel insert fell apart on our recent travels. What looks like happened the flimsy retainer frame fell off the bottom of the refrigerator main door and the aluminum insert slid down. I was able to put it all back together, just can’t believe this happened. We had a 2018 25’ Flying Cloud and I really like that refrigerator. This one seems like a junk.
06-22-2020, 05:39 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
yes; same thing happened to me. I used construction glue and re-attached the trim piece along the bottom edge of the door that holds the panel in place. No issues since I did this fix.
06-22-2020, 05:41 PM
2018 25' International
Slidell
, Louisiana
Our signature has a strong looking refrigerator its a RM3762 the front panels look well designed. What model is yours?
06-22-2020, 07:52 PM
Austin
Here is a picture of our refrigerator.
06-22-2020, 07:58 PM
Austin
Looks like my next project. Thanks
06-22-2020, 08:09 PM
Slidell
, Louisiana
yeah that is a different model. Looks very pretty, too bad the quality does not match the appearance. Guess some strong polyurethane construction adhesive is in your future. Sorry I could not help.
06-23-2020, 09:38 AM
2021 25' Flying Cloud
2021 20' Basecamp
Celebration
Same for us - 2017 Serenity - Glue stopped holding after awhile and bottom plastic finally broke. Inside shelf od door broke as well. New door 450.00. However new unit is 2K
06-23-2020, 10:37 AM
2017 30' Flying Cloud
2008 23' International
Keremeos
, British Columbia
In 2017, a new Dometic fridge was installed in our 2002 Chinook motorhome. We continually have this problem. It snaps back in place, and then we forget about it until it happens again. Thanks for reminding us. Something else to put on the to-do list.
Interestingly, this hasn’t happened on our 2017 Airstream. Did I just jinx it?
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
06-23-2020, 11:05 AM
2005 31' Classic
Venice
I have a new one like yours in out 2005. I had a problem with the top frame always coming apart.
The fix...I trimmed 1/16 off the large front panel and now its fine. When the panel was in place and all the way down against the bottom, I could see that it was too tall. It was just too big for the clip locks to do their thing. Never happened again after the trim.
06-23-2020, 11:10 AM
2016 23' International
Silverdale
Refer door falling down
Wee bought new 23d serenity after about 14 months same problem. Took it airstream nw x 2 but, finally glued it at bottom. Since gluing no problem. Love that Airstream.
08-12-2020, 09:11 AM
2017 20' Flying Cloud
Williamson County
I was about to repair mine by adding some rivets between clip and panel or possible along the sides. Sounds like trimming might help too so thanks for that. Lousy design and PITA.
2018 GMC Canyon CCSB V6 Mallet Supercharger
2006 Chevrolet CCSB 2500HD 6.6T LBZ
05-03-2022, 01:29 PM
Toaster Life
2010 23' International
Tucson
looking to revive the fridge panel thread
If the roads are bumpy my panel which is ever so slightly bowed seems to pop off the bottom plastic retainer and slides down as soon as I open the door. So far bracing the bottom of the door with popsicle sticks to hold it up tight seems to be working but I am looking for alternative solutions.
When we are about to set off in our now 12 year old CD, I have bungees to keep the pull out draw near the door closed, tiny bungees holding the round sink doors closed, the same under the bathroom sink and I barricade the fridge door shut with a mop held in place with more bungees to the pull out kitchen shelf opposite.
The barricading and bungees seem to work but always looking for better ways to do things - all advice welcome.
05-03-2022, 05:51 PM
Williamson County
Just a follow up on my post #11 above. I trimmed ours slightly as suggested, bonded top and bottom trim in place and added two pop rivets at the top corners through the trim and into the panel. Many miles later all is good.
05-04-2022, 02:19 PM
S/O#080
2006 30' Classic S/O
Naples
Domestic NDR 1062 parts
Hi all! Failing at finding new fridge and freezer handles for my Dometic. Any ideas?
05-04-2022, 06:29 PM
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel
Hi Tschupp
Try this link. Enter your Dometic model in the search box.
https://www.manualslib.com/
If you go to the Dometics site you can find out which models are still in production. The RM3762 in my 2009 Flying Cloud is still available. https://www.dometic.com/en-ca/outdoo...-refrigerators
Good Luck!
Best, Burnside
"To err is human, to air is devine."
06-25-2022, 07:06 PM
Georgetown
Dometic Refrigerator door panel falls apart
Hey folks, after some bad bumps in our 3,337 mile summer trip this week, we too suffered the panel falling off the Dometic fridge issue. After looking the design over, it seems pretty poor. The panel rests just on the two short pegs and can easily fall off. The trip piece at the bottom is no way strong enough to hold it.
After taking a few measurements, I whipped up a design for a better ledge piece that can hang off the pegs. Printed it on the 3D printer and worked like a champ.
Also added some child cabinet safety straps that stop the fridge from opening enroute. Pictures of all below.
Gary
08-23-2022, 09:35 AM
2022 20' Basecamp
Cloverdale
May be late to the discussion, we had the front fridge panel falling of after some rough roads in the BC mountains. Solution-removed the panel trim top and bottom- it clips in so careful not to break the clips- then applied a strip of 3M double sided tape about 2/3rd the length of the panel on the inside. Carefully realigned the panel, then replaced the top and bottom trim. No issues since. Note. This goes easier with the extra set of hands from your traveling companion.
08-23-2022, 10:58 AM
2018 27' Globetrotter
Mooresville
We had this repeatedly occur on a 2018 Globetrotter on rough roads in Newfoundland. We used the double sided tape method with good results as well.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
09-16-2023, 02:54 PM
2017 19' International
Tallahassee
This slipping-refrigerator-cover thing is driving me crazy. It is very hard to get it back in place, and it will, eventually (and sometimes soon!) pop loose and slip again.
Currently in the slipped-apart stage.
I just bought some double-sided tape for another project, and so I am going to give your solution a try.
Thanks for sharing your tip.
09-17-2023, 04:40 PM
Toaster Life
Tucson
Gary
I came up mid-trip with a less high tech solution - I took out one of the fridge shelves and wedged it in between the bottom of the door and the door frame - fits perfectly and supports the door (and plastic frame holding the door cover) in place - no problems since then but not as elegant as your solution.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
