RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-01-2020, 03:58 PM   #1
bella_intl's Avatar
2017 27' International
Lewes , Delaware
Rear Camera
Has anyone replaced the rear camera on their trailer? I have a 2017 Int 27' RBQ with a rear camera that came installed. The camera housing is allowing a bit of moisture into the housing resulting in a much degraded image. I used a hair dryer on low to warm the housing and eliminate the moisture. That worked to show that the camera was working fine. I looked at how to remove the housing and it looks like it is not meant to be removed. The wire harness for the camera goes into a hole in the trailer. My thought is that if I dismount the camera housing with camera, the wire harness may be able to be pulled out of the hole allowing me access to the connection between the trailer and the camera. However, I'm reluctant to start pulling on the wire harness with no idea of whether this will work.
Bella and the Beast
Bella - 2017 International Serenity 27FBQ
Beast - 2017 GMC Yukon Denali
bella_intl is offline   Reply With Quote
Old 11-26-2020, 10:49 AM   #2
2017 23' Flying Cloud
North Riverside , Illinois
Replaced my voyager camera for same reason. 2017 FC 23D, used the same mounting bracket and just spliced wire. There is some slack tucked in the skin but don't go crazy on yanking it. I maintained the original grommet and just added a bit of silicone for good measure. Took me 20 minutes to do so its not tough.
soleone is offline   Reply With Quote
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 06:01 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
Rear View Video Trailer Camera Mount Location chaimemet Towing, Tow Vehicles & Hitches 10 02-07-2008 09:15 PM
Sony Rear View Camera gunworks Electronics & Connectivity 1 10-08-2005 02:27 PM
