There are two LED lights attached to the underside of the storage cabinet above the dinette table. They were working fine, but now they do not come on when I turn the rocker switch to on. My first thought is that the rocker switch is bad or a wire came loose from the rocker switch. I'm non travel now and do not have a meter or jumper to jump across the wires at the switch to see if the switch is bad. Just wanted to see if anyone has experience with this type of issue and how they solved it.
Bella and the Beast
Bella - 2017 International Serenity 27FBQ
Beast - 2017 GMC Yukon Denali
-- check the fuse
-- pull the light and use a simple 12v tester (e.g. another light you know works) to see if there's power there.
-- pull the switch and test the leads and the switch (again with a simple "lightbulb" tester)
A multimeter does make things easier and they can be had for about $20. Many uses in the RV!
I pulled the switch to test for power through the switch. I found that one of the leads to the switch is broken. The wire leads have copper spades on the end that plug into the back of the switch. A piece of the copper spade is still in the middle switch and it is not clear how to remove that piece from the switch. I will need to obtain a piece of wire with the proper spade to splice in place of the broken spade. I have attached photos of the switch, the broken lead is by my fingers in the second photo, it is a three rocker gang switch, American Technology Components AH-ASY-3-5-001. It does not show up on their website. I sent a note to Airstream to see what they say.
Bella and the Beast
