Old 02-27-2021, 12:53 AM   #1
St Petersburg , Florida
Just put deposit down 25FBQ. What is the real dry unit & tongue weight when deliver
Hi,
I just got deposit down on 25FBQ with hatch 1AC
I know the Dry weight is always a bit higher than in brochure and tongue weight.
Does anyone here got 2021 25FB and weight their dry weight and tongue weight when unloaded? how many AC and if hatch will make heavier?
jimmyle1511 is offline   Reply With Quote
Old 02-27-2021, 08:35 AM   #2
ts8501's Avatar
2022 25' International
NEW PRAGUE , Minnesota
I am very interested in replies to your question. I want to configure same as yours, except front twins versus queen.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
ts8501 is offline   Reply With Quote
Old 02-27-2021, 08:50 AM   #3
2014 25' Flying Cloud
Temple , Texas
I do not know about a 2021, but our 2014 going down the road with a WDH, propane, water, and personal items is a tad over 1100 lbs. Yours is going to be heavier than you are thinking, certainly more than the 875 lb dry wt. You have a very nice AS, I hope you enjoy your travels this year and many more!
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 06-02-2021, 08:17 AM   #4
Jeff7176's Avatar
2018 25' International
Full-time , Traveler
Mine is a 2018 25FB with 1 AC and our TW is about 1,150 when loaded for camping.
Jeff7176 is offline   Reply With Quote
Old 06-02-2021, 08:45 AM   #5
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
We had a 2020 Int 25FBQ no hatch. My guess is the hatch will add 50-100lbs at most...very little. Being the weight is far aft, it should lighten your hitch...guessing 20ish lbs. The heavy hitch on the 25FBQ is due to geometry & storage location. 90% of your useful storage is up front on the hitch. You don’t have much flexibility shifting weight by packing smart. Example: my 30bunk has a fully loaded hitch weight of 865. That being said, I did tow my 25FBQ with and F-150 6,600 miles all over the country. I’m going to push either a Hensley Arrow or ProPride hitch at you. Many will tell you you don’t need it. ...you don’t need an AS either. I have properly setup an equalizer & blue Ox. I used the Blue ox for most of my 6,600 miles, it worked well...but not perfect. I could still feel trailer sway...especially in 25-30mph crosswinds, spontaneous 50-60mph gusts. I switched to a Hensley and astonished at the difference. Zero sway...zero!!! It works as advertised. ...pro Pride will do the same.
- Stewart
s1000pre is offline   Reply With Quote
Old 06-02-2021, 09:06 AM   #6
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
Congratulations. You are buying the longest lasting trailer ever made.
I think there is a 25 in this thread:
https://www.airforums.com/forums/f23...in-222675.html
Feel free to help populate it.
Peter417 is offline   Reply With Quote
Old 06-07-2021, 07:35 AM   #7
TexasVine's Avatar
2021 27' International
Fredericksburg , Texas
Congrats on the new AS. We have a the hatch door and I can't imagine it adding more than 50 pounds. Hinges, lock mechanism, perhaps a more reinforced window and trim as well as a screen door are in the modification.
TexasVine is offline   Reply With Quote
put down a deposit! kukula 2016 - Current Flying Cloud 44 12-24-2020 12:55 PM
JUST put deposit down on 2018 AS!!! astroboy18 Airstream Trailer Forums 20 05-08-2017 06:36 PM
Need help with bedding sizes. I just put a deposit on the Sport 22fb. I believe I was megster Our Community 16 01-03-2015 10:24 AM
Just put deposit down! terry.morrow Member Introductions 29 06-16-2013 01:52 PM
Just Put My Deposit Down On The '06 75th Anniversary Prototype Bambi! :) ggoat!!! Our Community 9 04-16-2010 12:21 AM
