Dexter Axel No-Lube Failure
I expect this not to be published here, but here it goes. I have a 2023 International on order. Was expecting it in early August. I just received a letter from Air Stream that the Nev-R-Lube Dexter axels have a wheel falling off issue due to the failure of a washer. Unknown what older versions are affected by the issue. It looks like my new trailer will not be coming in August. Very sad household here. Just thought I would make you all aware. It is affecting all models of Airstreams that use the Nev-R-Lube axel that are in production, not just the International. Who knows what older axels are affected???
