Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2016 - Current International
Old 09-22-2020, 05:45 AM   #1
Powerrunner's Avatar
2019 30' International
Battery compartment re-cabling
Looking to re-wire the battery compartment, since AS did a terrible job with cable management, making it difficult to maintain proper water levels. Has anyone done this? What is the gauge cable and were did you purchase longer cables?Click image for larger version
Powerrunner is offline   Reply With Quote
Old 09-22-2020, 08:00 AM   #2
Mollysdad's Avatar
I made my own when I installed a battery disconnect.
I used 2 AWG wire sourced from a marine supplier.
Here's one:
https://www.bestboatwire.com/collect...tery-cable?p=2
or
https://shop.pkys.com/Battery-Cable_c_34.html
Most suppliers will make cables for you. I just wanted to do it my way. Be aware that 2AWG and 2-0 AWG are very different. 2-0 means 00. 4-0 means 0000.
I recall Airstream used 4AWG and 6AWG, much smaller.
You can see my jumpers go outside the battery handle so the fillers are accessible.
The battery posts are 5/16" so your terminals will be sourced for that.
Mollysdad is offline   Reply With Quote
Old 09-22-2020, 08:35 AM   #3
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
A/C-D/C Supply has what ever you need, in any size, in any length, with any connector type. Prices are very reasonable, fast shipping, and great customer service.
https://www.ebay.com/str/AC-DC-WIRE-...p2047675.l2563
I have no financial interest in their company, but I am a satisfied customer with multiple orders over the past year and a half. One order came damaged by FedEX and when I e-mailed the owner, he sent an immediate replacement shipment. Did not require me to file against FedEX, although it was clearly run over and dragged by forklift or truck during shipment (afterwhich someone at FedEX put the clearly damaged cables insided a new FedEX envelope and delivered anyway).
My last order was 1/0 cable with Anderson connectors for quick disconnect capability.
rowiebowie is offline   Reply With Quote
Old 09-22-2020, 10:57 AM   #4
Thanks as l will look into this.
Old 09-22-2020, 06:16 PM   #5
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
I remove the two cables that Airstream installed ( one to the “trailer” and one to the inverter) and replaced them with one 1/0 cable that I made. I bought a crimper on Amazon and used welding cable which is extremely flexible. I did this when I installed a battery disconnect and a Victron battery monitor.
billrector is offline   Reply With Quote
Old 09-22-2020, 11:12 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Before I moved to lithium.....
ID:	379284   Click image for larger version
wulfraat is offline   Reply With Quote
Battery Cabling Question RivetCrazy Batteries, Univolts, Converters & Inverters 6 03-10-2020 04:02 PM
Best way to run cabling to forward compartment 23FB chris_kelly Electronics & Connectivity 0 07-20-2017 07:45 PM
T1N Interstate, mid bath- drivers side cabling? Lotus54 Sprinter and B-van Forum 13 03-04-2017 07:33 PM
Television cabling connections C21Tiger Airstream Motorhome Forums 0 10-03-2016 10:07 PM
