Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Oddities
Old 12-16-2011, 05:01 PM   #621
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Originally Posted by REDNAX View Post
Should ask Andy to see who has built the tallest A/S.
An interesting skirt, plus clearance & tail light configuration
Thats cool..
Just to prove I dont supersize everything I took my favorite micro forklift "Guido" out for a spin today
Darkspeed is offline   Reply With Quote
Old 12-16-2011, 05:08 PM   #622
Vintage Kin
Fort Worth , Texas
Had some customers once with a WWII era fork truck with a fine old Continental onboard. 58-years old and ran great.
Old 12-16-2011, 05:16 PM   #623
Darkspeed's Avatar
1972 31' Sovereign
You guessed it
2000lb y112 continental 4 converted to lp
70" tall and can drive through a 36" house door
I once picked up a 5400lb battery with it
Old 12-16-2011, 05:31 PM   #624
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Originally Posted by Darkspeed View Post
Thats cool..
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): https://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: https://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 12-16-2011, 06:19 PM   #625
1994 30' Excella
Mississauga , Ontario
Your roof looks good. Is the Supertherm paint finish comparable to an automotive finsih in appearance or is it a bit rough textured?
Al
Al and Jean
TAC ON-3
Old 12-16-2011, 10:30 PM   #626
Darkspeed's Avatar
1972 31' Sovereign
Al
It is a very mat finish
Old 12-16-2011, 10:30 PM   #627
Darkspeed's Avatar
1972 31' Sovereign
Originally Posted by exthemius View Post
Exactly!
Old 12-17-2011, 10:28 AM   #628
1994 30' Excella
Thanks. Are you going to leave it that way or coat with a clearcoat so it stays cleaner in weather? Just wondering if it will get very dirty if the finish is rough.
Al
Al and Jean
TAC ON-3
Old 12-17-2011, 05:02 PM   #629
Darkspeed's Avatar
1972 31' Sovereign
Al
I think the mat texture is a function of its ability to dissipate heat. If I cleared it I would be vastly reducing its surface area so going to let it be.
Old 12-17-2011, 05:12 PM   #630
1981 31' Excella II
New Market , Alabama
Where is the AC? You just going to camp in the winter?
Perry
After much delay I got the first coat of Supertherm on..
Will do two more tomorrow..
Once this is done Im going to do a touchup repolish as I have marked the skin with cleaner and tree gook..
Got down from the roof to look at my work... cant see any of it from the ground
Old 12-17-2011, 07:20 PM   #631
Darkspeed's Avatar
1972 31' Sovereign
Perry
I'm using a split system heat pump mounted on the a frame
Old 12-20-2011, 02:27 AM   #632
Vintage Kin
Fort Worth , Texas
Think I found your moho candidate. Just needs-repower with an 8.3L Cummins: Scroll a short ways into story . . a mobile training laboratory:
Travco: The Shaggy Story
Old 12-20-2011, 11:17 AM   #633
Darkspeed's Avatar
1972 31' Sovereign
I like the lab!
What is this though? trailer converted to moho??
Old 12-20-2011, 11:25 AM   #634
Darkspeed's Avatar
1972 31' Sovereign
I like the lab!
Found it :
Fred's Airstream Archives - 1970 Motorhome conversion Classic Motor Home
Old 12-20-2011, 09:13 PM   #635
Darkspeed's Avatar
1972 31' Sovereign
VeggieBullet +1 came by today - nice couple
Old 12-22-2011, 04:31 PM   #636
Darkspeed's Avatar
1972 31' Sovereign
Im trying this for window latches
http://www.airforums.com/forums/f454...ml#post1085377
Old 12-22-2011, 07:21 PM   #637
my3sonsdad's Avatar
Vienna , VIRGINIA
prep work for Supertherm
Other than the fan installs & patching work did you do any other surface prep before applying the Supertherm?
2001 Ford Excursion 7.3L
my3sonsdad is offline   Reply With Quote
Old 12-22-2011, 08:48 PM   #638
Darkspeed's Avatar
1972 31' Sovereign
sanded with 800 grit and a random orbital sander
Old 01-03-2012, 10:43 AM   #639
Darkspeed's Avatar
1972 31' Sovereign
Installed two 40G grey tanks and one 40G black tank
Started fitting the floor
Went to the bus conversion rally - so want one now!
ID:	148193   Click image for larger version
ID:	148195   Click image for larger version
Old 01-03-2012, 01:41 PM   #640
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
What happened to the 1955 40' Greyhound ?
FC7039 is offline   Reply With Quote
Leveling Airstream for Shell off guenther64 Repairing/Replacing Floor &/or Frame 2 06-28-2011 06:41 PM
Shell removal confusion P&K Repairing/Replacing Floor &/or Frame 6 05-21-2011 06:32 PM
Dry fitting shell..shims needed? Becky B. Belly Pans & Banana Wraps 2 05-17-2011 05:44 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell off or on? Breadbug Repairing/Replacing Floor &/or Frame 3 02-06-2011 11:06 AM
