09-07-2011, 09:18 AM
#261
Tool Hoarder
West
Originally Posted by Darkspeed
I'm guessing 80hrs. There were some spots on the endcaps and upper sides that had to be sanded and the sanded areas take longer to polish. It's actually fun because you can see the progress and when you take a break you can't wait to get back to it.
If it is xm radio - for me I listen to the VERGE
Gonna have to check that one never heard it.
09-07-2011, 11:30 AM
#262
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
09-15-2011, 10:18 AM
#263
1959 17' Pacer
Long Beach
Trailer done yet Dark?
09-15-2011, 04:55 PM
#264
moderator
2016 27' International
Wilton
Dark found match.com
Trailer is delayed...
Seriously.. you're doing a great job!
Vinnie
09-15-2011, 06:30 PM
#265
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge
Sir, I notice you are sanding your a aluminum with a palm sander to take off the clear coat? I hope not... The better way to do this is clear coat remover!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
09-29-2011, 12:16 PM
#266
1964 22' Safari
modesto
Polishing
Hey Dark, great job!
I am intrigued, I have never heard of anyone using Black, White bar for airstream polishing.
From your photo's I think the finish looks awesome after polishing with the white bar.
How are the swirl marks if any, close up?
Would you follow up with a cyclo type polisher?
Buy the way, have you decided what you are going to do for you door on the Falcon? Standard style or by-opening airplane style with built in fold down step??
Dennis
09-29-2011, 02:48 PM
#267
1959 17' Pacer
Long Beach
Dennis
Whatever he does, the Falcon needs to be impenetrable to Imperial SOB Troopers
09-29-2011, 07:41 PM
#268
1964 22' Safari
modesto
Witch model DeWalt are you using??? I am wandering about what the RPM is on yours.
Dennis
10-05-2011, 08:50 AM
#269
1972 31' Sovereign
Wesley chapel
Dennis
http://www.dewalt.com/tools/metalwor...rs-dwp849.aspx
Run it at full
10-05-2011, 08:52 AM
#270
1972 31' Sovereign
Wesley chapel
No. It was to pattern the top for painting with SuperTherm
10-05-2011, 08:53 AM
#271
1972 31' Sovereign
Wesley chapel
Iv been helping with opening a new location of the family business so I have been off the AS for a while.
10-05-2011, 05:40 PM
#272
1972 31' Sovereign
Wesley chapel
Did some shopping today..
240lb of alclad
2 fantastic fans
3G supertherm
12G HSC1000
1200bft closed cell e84 foam
All new exterior lights in led
3 tier electric kwikee steps
2 39G black / grey tanks
Rivets, trempro, etc...
10-05-2011, 07:29 PM
#273
1960 26' Overlander
1963 24' Tradewind
El Paso
240lb of alclad
2 fantastic fans
3G supertherm
12G HSC1000
Sounds like you're ready to hit it hard again!
10-05-2011, 07:59 PM
#274
1973 25' Tradewind
1962 22' Safari
Augusta
, Georgia
What is the size of the 39g tanks? Starting to look for water and grey tanks to fit inside a new 5" frame.
10-05-2011, 10:30 PM
#275
1972 31' Sovereign
Wesley chapel
Mine are 9.5" deep. They won't fit your frame
http://item.mobileweb.ebay.com/viewi...id=91620885214
10-06-2011, 12:14 PM
#276
1959 17' Pacer
Long Beach
There are quite a few here at RV Surplus. They also have really reasonable prices and shipping, with all the fittings custom and sensors installed if you want.
Be advised, they do take 4 weeks as they are custom built. Also, expect up to half inch tolerance on the length and width dimensions--I found that out from the manufacturer just before I ordered a 54" tank to fit my 54.00" frame spacing. I was limited to only 4" deep on my older frame, but you should have more options, especially if you are willing to push out your belly pan a little bit to fit the 5.75" deep tank options.
10-06-2011, 12:35 PM
#277
1972 31' Sovereign
Wesley chapel
What I really need to find is a lower half of a door / door frame I have been calling around with no luck
10-06-2011, 07:37 PM
#278
1972 31' Sovereign
Wesley chapel
Good news! A local AS guy has a door for me!
10-10-2011, 06:09 PM
#279
1972 31' Sovereign
Wesley chapel
Busy day! Installed two of the primo fan-tastic fans, installed rivets in all the screw holes where the AC use to be, patched the AC hole, patched the mid fan hole, Still need to patch the old fridge vent, antenna hole, both stack vents, then the top will be ready for supertherm...
10-10-2011, 11:05 PM
#280
1972 31' Sovereign
Wesley chapel
I have a new problem. I can't reach the fans when I stand in the trailer lol.
