Originally Posted by Darkspeed
The floor is getting two inches of closed cell foam board. The spray foam is for the shell, it will be sprays in 2" thick on top of the HSC-1000 ceramic. I have used it before and never had a heat problem. I will report on the results.
I'm wondering, using the HSC-1000 ceramic, and the spray foam, any idea what kind of extra weight is involved? Loved the fact that you were inside of your trailer when outside temps were close to freezing, and one light bulb had inside temp (after ceramic I believe) close to 70. Being in Florida, keeping the heat out, as well as the cold is important, but weight is a big issue with my moho as well.
Thanks for any info you can provide, Derek
