Old 09-07-2011, 09:18 AM   #261
Tool Hoarder
West , California
Originally Posted by Darkspeed View Post
I'm guessing 80hrs. There were some spots on the endcaps and upper sides that had to be sanded and the sanded areas take longer to polish. It's actually fun because you can see the progress and when you take a break you can't wait to get back to it.
If it is xm radio - for me I listen to the VERGE
Gonna have to check that one never heard it.
marzboy is offline   Reply With Quote
Old 09-07-2011, 11:30 AM   #262
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
http://www.thevergeonline.com/
Darkspeed is offline   Reply With Quote
Old 09-15-2011, 10:18 AM   #263
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Trailer done yet Dark?
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 09-15-2011, 04:55 PM   #264
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Dark found match.com
Trailer is delayed...
Seriously.. you're doing a great job!
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 09-15-2011, 06:30 PM   #265
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Sir, I notice you are sanding your a aluminum with a palm sander to take off the clear coat? I hope not... The better way to do this is clear coat remover!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 09-29-2011, 12:16 PM   #266
batman's Avatar
1964 22' Safari
modesto , California
Polishing
Hey Dark, great job!
I am intrigued, I have never heard of anyone using Black, White bar for airstream polishing.
From your photo's I think the finish looks awesome after polishing with the white bar.
How are the swirl marks if any, close up?
Would you follow up with a cyclo type polisher?
Buy the way, have you decided what you are going to do for you door on the Falcon? Standard style or by-opening airplane style with built in fold down step??
Dennis
batman is offline   Reply With Quote
Old 09-29-2011, 02:48 PM   #267
1959 17' Pacer
Dennis
Whatever he does, the Falcon needs to be impenetrable to Imperial SOB Troopers
- Peter (and Marie)
TAC CA-15
Old 09-29-2011, 07:41 PM   #268
batman's Avatar
1964 22' Safari
Witch model DeWalt are you using??? I am wandering about what the RPM is on yours.
Dennis
Old 10-05-2011, 08:50 AM   #269
Darkspeed's Avatar
1972 31' Sovereign
Dennis
http://www.dewalt.com/tools/metalwor...rs-dwp849.aspx
Run it at full
Old 10-05-2011, 08:52 AM   #270
Darkspeed's Avatar
1972 31' Sovereign
No. It was to pattern the top for painting with SuperTherm
Old 10-05-2011, 08:53 AM   #271
Darkspeed's Avatar
1972 31' Sovereign
Iv been helping with opening a new location of the family business so I have been off the AS for a while.
Old 10-05-2011, 05:40 PM   #272
Darkspeed's Avatar
1972 31' Sovereign
Did some shopping today..
240lb of alclad
2 fantastic fans
3G supertherm
12G HSC1000
1200bft closed cell e84 foam
All new exterior lights in led
3 tier electric kwikee steps
2 39G black / grey tanks
Rivets, trempro, etc...
Old 10-05-2011, 07:29 PM   #273
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
240lb of alclad
2 fantastic fans
3G supertherm
12G HSC1000
Sounds like you're ready to hit it hard again!
desertair27 is offline   Reply With Quote
Old 10-05-2011, 07:59 PM   #274
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
What is the size of the 39g tanks? Starting to look for water and grey tanks to fit inside a new 5" frame.
DGJackson is offline   Reply With Quote
Old 10-05-2011, 10:30 PM   #275
Darkspeed's Avatar
1972 31' Sovereign
Mine are 9.5" deep. They won't fit your frame
http://item.mobileweb.ebay.com/viewi...id=91620885214
Old 10-06-2011, 12:14 PM   #276
1959 17' Pacer
There are quite a few here at RV Surplus. They also have really reasonable prices and shipping, with all the fittings custom and sensors installed if you want.
Be advised, they do take 4 weeks as they are custom built. Also, expect up to half inch tolerance on the length and width dimensions--I found that out from the manufacturer just before I ordered a 54" tank to fit my 54.00" frame spacing. I was limited to only 4" deep on my older frame, but you should have more options, especially if you are willing to push out your belly pan a little bit to fit the 5.75" deep tank options.
- Peter (and Marie)
TAC CA-15
Old 10-06-2011, 12:35 PM   #277
Darkspeed's Avatar
1972 31' Sovereign
What I really need to find is a lower half of a door / door frame I have been calling around with no luck
Old 10-06-2011, 07:37 PM   #278
Darkspeed's Avatar
1972 31' Sovereign
Good news! A local AS guy has a door for me!
Old 10-10-2011, 06:09 PM   #279
Darkspeed's Avatar
1972 31' Sovereign
Busy day! Installed two of the primo fan-tastic fans, installed rivets in all the screw holes where the AC use to be, patched the AC hole, patched the mid fan hole, Still need to patch the old fridge vent, antenna hole, both stack vents, then the top will be ready for supertherm...
Old 10-10-2011, 11:05 PM   #280
Darkspeed's Avatar
1972 31' Sovereign
I have a new problem. I can't reach the fans when I stand in the trailer lol.
Leveling Airstream for Shell off guenther64 Repairing/Replacing Floor &/or Frame 2 06-28-2011 06:41 PM
Shell removal confusion P&K Repairing/Replacing Floor &/or Frame 6 05-21-2011 06:32 PM
Dry fitting shell..shims needed? Becky B. Belly Pans & Banana Wraps 2 05-17-2011 05:44 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell off or on? Breadbug Repairing/Replacing Floor &/or Frame 3 02-06-2011 11:06 AM
