Old 05-22-2017, 03:04 PM   #1
dvgofaz's Avatar
2005 34' Classic
tucson , Arizona
door caster?
So, I've searched the forums and can't find an answer for this, why is there a small caster wheel on the upper right corner of the entry door to my 2005 classic?Click image for larger version
Name:	door caster.jpg
dvgofaz is offline   Reply With Quote
Old 05-22-2017, 03:19 PM   #2
gator.bigfoot's Avatar
KW , Ontario
When the awning is down and it interferes with the door the door won't wreak the awning. The wheel will push up the awning instead by rolling across it rather than scraping across it.
gator.bigfoot is offline   Reply With Quote
Old 05-22-2017, 05:06 PM   #3
dvgofaz's Avatar
2005 34' Classic
tucson , Arizona
AHA! I guess if I used my awning more I would have seen that! Thanks.
Old 05-22-2017, 09:26 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have seen some back yard engineering in my day. This takes the cake.
And. What does one pay for an A$ with this accessory?
Old 05-22-2017, 09:32 PM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Back in the 80's, that little wheel was standard equipment on Avions. Good insurance, rather than putting a tear in the awning.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-22-2017, 09:57 PM   #6
FishByFly's Avatar
2017 25' Flying Cloud
Fort Worth , Texas
On our 30' bunkhouse, I installed Awning Bows. Worked much better on providing door clearance and prevented water bathtub pooling effect.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 05-23-2017, 08:51 AM   #7
dvgofaz's Avatar
2005 34' Classic
tucson , Arizona
So I opened the awning and sure enough that caster protects the canvas when the door swings. In fact it has even 'drawn' a dark arc on the canvas that looks like a faded water stain. I like the idea of staves to support the canvas,if they were just the right length I could store them in the tube.
Old 05-23-2017, 09:51 AM   #8
Kevin245's Avatar
Backyard engineering? These little devices are commonplace on many RV brands, typically an aftermarket add on. Camco sells this in a wheel configuration. As for the price, usually $4 to $7 depending on where you shop.
http://www.campingworld.com/shopping...r-roller/86455
William C. Swinney
Kevin245 is online now   Reply With Quote
Old 07-11-2017, 09:02 AM   #9
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Also available from Zip Dee. I have one but have not installed it yet
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-10-2017, 10:13 PM   #10
jeffndaile
Jeffndaile's Avatar
2013 28' Flying Cloud
Clarkston , Washington
PLEASE Do not use the wheel on your door!!!
Though the wheel looks like it will not harm the fabric on your awning, it will very effectively do the same thing as if you didn't have it at all. I have known many people to use these and in very short order the wheel will cut through the fabric or at the very least make a very big Mark in your awning. The very best thing that I have done and will continue to do is do not let your door come in contact with the awning Period.
Jeffndaile is offline   Reply With Quote
Old 04-09-2018, 06:16 AM   #11
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Here's how I lift my awning just enough to keep my door from dragging on it. I've used this PVC gadget for 5 years with no damage to the awning at all.Click image for larger version
NOAZRK2690 is offline   Reply With Quote
Old 04-09-2018, 10:06 AM   #12
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Originally Posted by NOAZRK2690 View Post
Here's how I lift my awning just enough to keep my door from dragging on it. I've used this PVC gadget for 5 years with no damage to the awning at all.Attachment 308257
Clever!
sheriff1 is offline   Reply With Quote
Old 04-09-2018, 09:10 PM   #13
2007 22' International CCD
Could you please publish the dimensions and size of tubing used? This is a super clever idea!
Old 04-10-2018, 07:54 AM   #14
NOAZRK
NOAZRK2690's Avatar
3/4" PVC, 4 END CAPS, 2 "T's. Cut 4 horizontal pices about 8" long. Assemble horizontal pieces. Insert vertical PVC any length. With awning tilted for rain runoff, open door and push up awning as needed on your AS. Cut vertical PVC length. Insert into bottom "T". Adjust as needed. Note: there is no standard length for the vertical PVC due to trailer and awning lengths
Old 04-10-2018, 03:52 PM   #15
FishByFly's Avatar
Fort Worth , Texas
Great solution. And one could spray paint color of choice. Even aluminum
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Old 04-10-2018, 03:55 PM   #16
Great!
One add--use Schedule 40 PVC.
It's lots stronger and thicker than the cheap Schedule 125 thin, easily broken stuff.
Schedule 40 has much thicker tubing walls than 125...about 1/8 inch vs. paper-thin...
Old 08-14-2020, 02:38 AM   #17
Roadhoop's Avatar
2016 25' Flying Cloud
Fort Worth , Texas
This PVC solution put too much pressure on the door's eye brow gutter, causing it to leak...
Roadhoop is offline   Reply With Quote
Old 08-16-2020, 10:24 PM   #18
jeffndaile
Jeffndaile's Avatar
Originally Posted by dvgofaz View Post
So, I've searched the forums and can't find an answer for this, why is there a small caster wheel on the upper right corner of the entry door to my 2005 classic?Attachment 286087
The short answer... the previous owner installed that wheel to keep the awning from rubbing on the edge of the door ... the real fix? Is simply to put one or two more turns on the roller spring.. if the fabric is taught it will not rub on the door.
Old 08-18-2020, 08:20 AM   #19
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I just raise the awning on that side high enough to clear.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
jack caster wheel on '54 wanderer lunartic Jacks, Stabilizers, Lifting and Leveling 3 08-06-2018 12:41 PM
Replacing Foot of Hitch With a Caster Vitaver Jacks, Stabilizers, Lifting and Leveling 6 02-09-2017 03:50 AM
jack wheel caster 2 inches (in Uk or Europe) GaŽl Jacks, Stabilizers, Lifting and Leveling 4 08-08-2014 04:24 AM
