Old 03-10-2020, 10:05 PM   #1
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Airstream Truck Camper
I thought that only Avion made a truck camper. I stumbled across this Airstream truck camper on route 151 in Virginia today. This would be a very interesting project.
DanClick image for larger version
ID:	363039Click image for larger version
ID:	363041Click image for larger version
ID:	363047Click image for larger version
ID:	363042Click image for larger version
ID:	363043Attachment 1Click image for larger version
ID:	363044Click image for larger version
Old 03-11-2020, 01:46 AM   #2
Sag Harbor , New York
Great find, Dan!
Your post got me moseying around the forum. Did you know there is a thread for "Abandoned aluminum?"
https://www.airforums.com/forums/f41...um-108563.html
Nice!
The Photography forum has some other odd-ball threads on the older pages:
https://www.airforums.com/forums/f415/
Cheers,
Peter
Old 03-11-2020, 06:02 AM   #3
Around , Town
Am not so sold that this is an example of an Airstream camper insert as opposed to a modified Airstream trailer dropped onto a stake-body.
IIRC, even the Avion camper insert had the common rear entry door.
Definitely an awesome find though!
JayTheCPA is offline   Reply With Quote
Old 03-11-2020, 02:08 PM   #4
Agreed. Check the sloppy piecemeal aluminum sheet metal work all around the cab-over part.
Peter
Old 03-11-2020, 06:23 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Peter
Peter & JayTheCPA
I also agree. The sloppy aluminum work at the bottom also supports this statement.
Old 03-12-2020, 12:49 AM   #6
Disco Stu's Avatar
1951 18' Clipper
1965 17' Caravel
Ballarat, Victoria , Australia
1948 Trailwind?
Disco Stu is offline   Reply With Quote
Old 03-12-2020, 07:11 AM   #7
Images: 59
Originally Posted by Disco Stu View Post
1948 Trailwind?
Looks like it married a '65 F350.
Old 03-12-2020, 09:12 AM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
You’re good. It is actually a ‘64 though, according to the for sale sign.
Dan
Old 03-12-2020, 09:17 AM   #9
1976 31' Sovereign
Oswego , Illinois
1967 Northern Il. president Roger Piper of Princeton Il. had a 26 ft. AS mounted on modified frame [stretched] ford truck. A frame was cut off & axles removed. Maybe some pics in archives of this mod. If any found please post as I did not take any at that time.
Old 03-12-2020, 12:46 PM   #10
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
But what really needs to be said: It’s butt-ugly!
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 03-12-2020, 04:34 PM   #11
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Awww - beauty is in the eye of the beholder! I would LOVE to have that and do what Moosetags does - that in the truck bed and towing another AS behind.
Old 03-14-2020, 03:43 PM   #12
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
A 1947 Liner gave its life for this . . .
The Airstream shell on the Ford flatbed truck is from a 1947 22' Liner serial number 1078 per the s/n tag. This is an early Liner shell with standard household door hinges between the body and outer door only; they do not extend to the inner door. Once loosened, the inner door-within-a-door is removed and usually placed underneath the trailer or, in this case, the truck.
It is easy to imagine the pipe frame chassis of the original Liner eventually failed and was removed, leaving the shell to be repurposed.
I like the concept, but the execution is rougher than a cob. The metal skid strips of the wood flatbed floor add a new rub to an Airstream interior. Cleaning up the exterior and installing a functional but folksy interior could make this an eye turner for multiple reasons. The drawing board calls!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-14-2020, 06:26 PM   #13
Thanks for the thorough update.
Peter
Old 03-18-2020, 12:21 PM   #14
1968 22' Safari
Lake Elsinore , California
I saw a home-built pickup topper shell mounted on a Chevy 1500 once that looked as if it had been made by the Airstream factory.
All polished aluminum with rounded corners and rivets to hold it all together. No AS hitched up behind it, but it would have made a stunning combo on the road.
safaridave is offline   Reply With Quote
Old 03-18-2020, 01:06 PM   #15
rideair's Avatar
Looks like something Dave M. would have had that ran "Trailer Buff" for many years outside Nellysford, VA
I don't think he's doing trailers anymore, but not sure if he's gotten rid of his shop.
Stay Healthy,
Paul Waddell
rideair is offline   Reply With Quote
Old 01-20-2021, 06:04 AM   #16
redthies's Avatar
1963 19' Globetrotter
1967 17' Caravel
1974 29' Ambassador
Whiterock , British Columbia
Originally Posted by SteveSueMac View Post
Awww - beauty is in the eye of the BEERholder! I would LOVE to have that and do what Moosetags does - that in the truck bed and towing another AS behind.
Fixed it for you...
redthies is offline   Reply With Quote
Old 01-20-2021, 07:15 AM   #17
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
More correctly, it's what mooseatgs used to do. We sold the truck camper in 2017. We had some great times with the Outfitter truck camper, but in the last couple of years that we had it, we found that we were just not using it as much as we had originally. We reverted back to a 3/4 ton truck and have continued on with just Lucy.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 04-01-2021, 08:57 PM   #18
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Here are some incredible real “Airstream and Streamline Truck Campers” that I saw today in a TCT Facebook post.
Dan Click image for larger version
ID:	392184Click image for larger version
ID:	392185Click image for larger version
ID:	392186Click image for larger version
Old 04-02-2021, 03:00 AM   #19
Thanks for the great update to your thread, Dan, . . . fun to look back at old threads for entertainment in these challenging times . . .
Great find, Dan!
This "Airstream Oddities" forum has other interesting topics:
https://www.airforums.com/forums/f537/
1969 Ford F-250 Camper Special Truck with a 1968 Avion C11 Truck Camper Wppcdlh4 Airstream Classifieds 0 08-24-2017 12:45 PM
My truck is better than your truck Alluminati Towing, Tow Vehicles & Hitches 48 12-15-2016 03:23 PM
1965 Alaskan Truck Camper from Airstream Guy eBay Watch Airstreams on eBay 0 07-25-2011 06:50 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
