Old 04-01-2024, 11:57 AM   #1
2022 25' International
Belleville , Michigan
Zipdee Relax 12v Electronic Retrofit Kit - Michigan
This Retrofit Kit, supplied here exactly as its sold by ZipDee, is for converting a standard ZipDee contour awning to 12v electric awning.
Most of the parts were pulled off my new 2022 International 25FB when I converted the electric awning to manual, only used a couples times . I took those parts and ordered the rest needed new from ZipDee to make a complete Relax 12v Electronic Retrofit Kit. It comes with everything listed in the relax 12v electronic contour hardware pdf, except for the Optional Remote Control Package, which is how ZipDee sells the 12v Electronic Retrofit Kit for 3,790 currently.
The parts list includes:
  • Complete Head Casting Assembly
  • Complete Main Arm Assembly Front
  • Complete Main Arm Assembly Rear
  • Complete Contour Hinge Assembly
  • Complete Gas Rafter Assembly
  • Complete Main Control Board Wired With Enclosure Control Board Wired, Enclosure for Control Board
  • Wall Switch Assembly
  • Spring Change
  • Complete Motor Assembly with Drive amp; Adapter
  • Machined Motor Drive
  • Motor Drive Shaft Assembly
  • Machined Retaining Ring
  • 40ft of wire to go from the motors to the control board
  • Manual override closing kit
  • Printed manual and instructions
I include all the rivets including bulb tite necessary to install but I'd recommend having your own healthy supply of rivets just in case. You will also need a tube of exterior Airstream sealant for attaching the brackets.
Condition, As described above most of the parts came off my new 2022 International 25FB and were used a couple times, therefor I would describe them as "used like new". All of the parts and motors worked perfectly. Although in great cosmetic condition there might be blemish here or there.
Price 2,600 plus shipping if shipped
View this ad at Airstream Classifieds - Zipdee Relax 12v Electronic Retrofit Kit - Michigan
robwolff3 is offline   Reply With Quote
Relax awning retrofit kit The Colonel 2016 - Current Flying Cloud 10 02-26-2017 10:18 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
