Old 09-01-2017, 12:28 PM   #1
dasams's Avatar
Palm Desert , California
Zamp 160 watt portable solar kit (suitcase)
Title:
I just posted a new ad on Airstream Classifieds.
Purchased last year for a boondocking trip to Baja and rarely used since then. Reason is that we stay in full hook-up RV parks.
This is Zamp model ZS-US-160-P and comes with the Zamp carrying case. These Zamp suitcases are expensive and are recommended by AS. From 2017, AS uses a Zamp SEA connector on the battery box for quick and easy hook-up.
From the Zamp website:
"The most popular large sized universal portable solar kit will generate 160 watts at 9.4 amps and includes the integrated 5 stage 15 amp water proof solar charge controller to keep your 12 volt system protected..."
We paid $748 last Nov. Also included is the Zamp 15ft portable harness extension that was $37. I also have an extra ZAMP SAE plug-in port that I'll include but it's wired to the SAE standard, not the reverse polarity that Zamp uses. You simply put the red to the battery's negative terminal and black to positive. Or buy a new one from Zamp.
Pick-up in SF Bay Area preferred as it's heavy and shipping will be expensive.
The image above is from the Zamp website as the suitcase is in storage.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...-kit-suitcase/
dasams is offline   Reply With Quote
Suggestions on Upgrading stock coach batteries to 400 Watt from stock 160 Watt odonnell71 Sprinter and B-van Forum 5 05-07-2017 08:59 AM
Zamp 160 watt portable solar dznf0g Generators & Solar Power 20 03-02-2016 07:10 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 03:25 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
