Title:
I just posted a new ad on Airstream Classifieds.
WFCO Airstream DC to AC 1 KW Power Inverter USED about 3 years old. (Being replaced with 2KW unit) Does not come with remote control panel and RJ11 cable. Paintwork underside of unit shows minor corrosion from damp. Shipping cost quote based on your zip code.
Input:
12V DC, Output: 115V AC, Continuous Power: 1000 W. WFCO 1000 Watt power inverters provide high-efficiency power at full-load conditions with safeguards that include; overload protection, over-temperature protection, and short-circuit protection. The cooling fan enhances efficiency as its operation is controlled by the amount of load incurred by the inverter.
Specifications:
DC Input Voltage :
12V DC
DC Input Voltage Regluation : 10-15V DC
Output Voltage Frequency : 115 VAC/60Hz +/- 0.05%
Output Waveform : Pure Sine Wave (THD 80%
Continuous Output Power : 1000 W
Status Indicator Lights : Greed LED: AC Input Status, Red LED: Inverter Failure, Yellow LED: Battery Back Up Status
Transfer Switch : 8.5 A
Transfer Time :
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...ower-inverter/
