Old 06-05-2020, 11:37 AM   #1
Datta's Avatar
1968 22' Safari
Soquel , California
Wanted: Replacement Range for 1968 Airstream Safari
Hello out there in Airstream land,
The thermocoupler broke in the oven of our Magic Chef 3 burner range and I have heard from my usual sources the part is out of production, so we're looking to replace the whole unit.
The replacement needs to fit a 20.5W x 23H x 19D opening.
We are currently in Idaho, headed toward Michigan and will be circling back through the Southwest for our return route so bonus points if you're on our flight path and we can pick it up in person.
Not sure if I would get messages here, so to make sure it gets through you will want to text pics and info to my phone number below as well.
Thank you all!
Datta K
1968 Safari 22T
View this ad at Airstream Classifieds - Wanted: Replacement Range for 1968 Airstream Safari
Datta is offline   Reply With Quote
Old 06-17-2020, 09:04 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
I have one removed from a 1965 Caravel. works fine and it is removed sitting in my garage in South Carolina (Charleston) 29445 it is Brown in color and pretty clean, un damaged
smily is offline   Reply With Quote
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 1 02-09-2020 07:28 AM
New Tires - got Load Range E instead of Load Range D Hyperion 2009-2015 Flying Cloud 49 06-08-2016 06:47 PM
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Replace range/oven with range/microwave rkconway Stoves, Ovens & Microwaves 2 01-13-2009 03:58 PM
