This used suitcase portable kit is packed with thoughtful features to make your off grid venture hassle free. Ideal for medium RVs or projects, this panel generates 140 watts at 7.8 amps. The weather resistant, 5 stage, 10 amp charge controller is integrated into the panel to protect your
12 volt battery from overcharging, while its large digital display helps you keep tabs on your power usage. Includes rugged cover, Zamp side wall port, and quick connects for fast and easy hook up. Excellent condition.
140 Watt Portable Specs:
32.75 lbs
Closed Dimension 32.4" x 21.5 x 3.1
140 Watt Power Output
Generates 7.8 amps
10 Amp Solar Controller
View this ad at Airstream Classifieds -
Zamp 12V 140W Portable Solar Panels - California
