2022 Airstream Globetrotter 27ft front bed queen. What makes this Airstream unique are the upgrades!
Upgrades included:
3 additional 90 watt solar panels for a total of 5 panels with 450 watts charging power
2 100 amp hour lithium batteries 200 amp hour total
Victron Smart Battery Monitor connect to your solar controller and see how your solar and batteries are using power. Gives you State of Charge information which is useful when boondocking
Easy Starts on both AC units reduces power need at start up
Pepwave dual SIM modem router w/ Poynting MIMO roof antenna allows you to connect to 2 different cell services and create your own in trailer WiFi signal. You can even create a guest WiFi signal for your friends
Fan tastic Vent Ultra Breeze Rv Roof Vent Bug Screen allows you to travel with your roof vent open
Dual pedestal dinette table converted to single gas assist pedestal by Ultimate Airstreams
Drop down cabinet fronts under couch converted to pullout drawers by Ultimate Airstreams. Maintains the pull out bed functionality
32" Hisense Smart TV upgrade from the stock 27 LG TV
Furrion cast iron range grates upgrade from the not very useful stock burner grates
Tire pressure monitoring system see your tire pressures and temperatures in your tow vehicle. This addition helps your safety!
2 AC roof units upgraded by the factory from standard single AC unit
Low pressure quick connect port inside trailer
Insulated hot water pipes I insulated as many hot water pipes as I could reach to help get hot water faster to the shower and sinks
The Globetrotter also comes with a bunch of standard features some of which you cansee in the photos. Sleeps up to six. Separate fresh, grey, and blackwater tanks.
Ask any question you may have.
View this ad at Airstream Classifieds -
2022 Airstream Globetrotter 27 - California
