Old 08-19-2021, 07:44 PM   #1
2020 27' Flying Cloud
Saint Paul , Minnesota
2020 Airstream Flying Cloud 27 - Minnesota
Imagine going wherever you would like to go in the United States, Canada, Mexico. Wherever you can tow the Airstream that is where you can go. Imagine traveling through the southern states during winter! Or maybe you'd like to be in the northern states or Canada during summer! Pack the trailer with essentials, gas up the tow vehicle, hitch up the trailer and you are ready to go. With this Airstream you can boondock or staying in an RV park. We've had over 11,000 of equipment added to the Airstream. We are looking at motorhomes, that is why we are selling. If you are serious about purchasing an Airstream that is in excellent shape and self sufficient, contact Steve or Vicky.
FYI: Airstream just announced it is cutting back production by 15 percent . There will be definitely be longer wait times to fill orders.
Truffle Ultra leather
Three Awning Package
Second Air Conditioner there is a 15000 BTU and 13500 BTU
50 Amp Service
Convection Microwave in place of oven
Solar 240w Package Solar wiring upgraded AGM batteries to two lithium batteries, installation of two 90w Zamp solar panels by factory, installation of one 90w solar panel by owner making a total of 3 solar panels
  • Micro air EasyTouch RV 350 thermostat Bluetooth capability
  • Haloview Camera System 1 rear, 1 roadside amp; 1 curbside camera including a Haloview 7 monitor amp; mounts
  • Two Lithium Batteries Power LifePO 4 12V/75AH
  • Victron MultiPlus i3,000kVA Inverter Also included Victron MK3 USAB Interface, VE.BUS Smart Dongle for Bluetooth, External Battery Temperature Probe, amp; Victron energy Multi Control Panel
  • Two new pillow top deep twin mattresses
  • Air Flow mats between bed base amp; mattresses mats recommended to prevent condensation amp; mold
  • Bedding Two pillow top mattress pads, two sets of Airstream white sheets, two lightweight quilts, amp; two original bedspreads
  • Full articulating arm mount for the living room TV
  • Tire Minder 4 transmitters, powered with solar/batteries
  • Soft Starter for both ACs. Soft Starter reduces the starting current of the compressor avoiding damage to ACs amp; shorting circuits
  • 2 bases LP tanks
  • 90w Zamp solar panel extra panel added Zamp package installed by factory total 270w
  • Airstream teak shower mat shaped to fit the shower floor.
  • We Boost Drive 4G X 12 VDC power supply amp; 120 VAC power supply, Indoor Antenna and Outdoor Antenna mounted on roof
  • 3 Dexter Lift Kit Current height with air conditioners amp; the 3 lift = 10
  • Equal i zer Travel Trailer Hitch System 1,000 lb. maximum tongue weight amp; 10,000 lb. maximum trailer weight . Separate shank amp; ball included in sale.
  • 2 EU 2200i Portable Generators with pairing cord used for boondocking or power outages
  • Hitch Lock
  • Winterization Kit
  • Wire shelves added to the wardrobe closet shelves can be easily removed
  • Rivets amp; Rivet Tool
  • Miscellaneous items books, chocks, lock for hitch, etc
View this ad at Airstream Classifieds - 2020 Airstream Flying Cloud 27 - Minnesota
stevexs is offline   Reply With Quote
Flying Cloud 27FB :: 2020 Airstream Flying Cloud Bob May Airstream Registry Discussions 0 02-01-2021 12:25 AM
2020 Airstream Flying Cloud 25 - Minnesota Schurchill Airstream Classifieds 0 03-10-2020 09:16 PM
