Old 08-06-2020, 01:34 PM   #1
2011 20' Flying Cloud
Asheville , North Carolina
2018 Airstream International Serenity 27 - Washington
2018 Airstream International Serenity 28RB Queen. We love our Airstream our 4th , and used it mostly locally since purchase 9/22/17 , with less than 900 miles traveled. It is the 50 amp model, with 2 ducted heat pump units. It has a motorized main awning, the other 2 are manual. We had the regular oven switched out for a microwave/convection/grill. You can Google 2018 Airstream International Serenity and see the brochure with more details.
Gross Vehicle Weight: 5979
VIN Number: 1STJFYM28JJ540951
Purchase Date 9/22/17
Miles: 900
Sleeping Capacity: 6
Heat Pumps: 2
Awnings: 3
Water Capacity: 39
Interior
Asian Zen Theme/Tarket Comfort Style Flooring
Anti wicking Outside Edge Floor Sealant
Coat Key Hooks
Complete Aluminum Interior Walls and Ceiling
EcoBattTM Insulation
Electric/LP Water Heater 6 gal.; 9 gal. production
Fantastic Fan with Thermostat Automatic Rain Sensor
LED Interior Lighting with Dimmer
Overhead Roof Lockers with LED Lighting
Panoramic Front Windows with Blackout Shades
Probeless Tank Monitoring System
QuietstreamTM A/C with Heat Pump 2 Electronic Thermostat
Exterior
2 Deep Cycle Group 24 Batteries with Multi Stage Converter
4 Manual Heavy Duty Stabilizer Jacks
Airstream Custom Aluminum Step 19': Thule Aluminum Step
Aluminum Entry Door Handle
Aluminum LP Cover
Black Tank Flush System
Cable TV Hookup
Cast Aluminum Door Hinges
Cast Aluminum LED Taillights
City Water Inlet with Water Pressure Regulator
Custom Handcrafted 26" Wide Entry Door with Window
Dedicated Waste Hose Storage
Enclosed Aluminum Insulated Heated Underbelly
Exterior LP Quick Connect Service Port
Exterior Shower with Hot Cold Water
Goodyear ST225/75R15 Tires, Balanced
Hand Crafted Welded Extruded Aluminum Window Frames
Hand Painted Chassis
LED Dimmable Patio Awning Light
LED Entrance Light
Electric ZipDee Patio Awning with Sunbrella Fabric
LED Storage Compartment Light
LED Tank Service Light
License Plate Bracket with LED Light
Lockable Fresh Water
LP 2 30 lb. Steel Tanks with Auto 2 stage Regulator
Add Ons
Changed out standard oven for Contoure 1.2 cu. ft Stainless Steel Built in Microwave Oven with Convection/Grill.
Camper Service 3/3/18 Water pump replaced under warranty due to faulty seal
9/18/18 leaking low water drain valves replaced , gray water tank replaced due to sensor malfunctioning and minor cosmetic fixes under warranty.
View this ad at Airstream Classifieds - 2018 Airstream International Serenity 27 - Washington
Cheryle is offline   Reply With Quote
Old 08-08-2020, 03:39 PM   #2
2019 30' International
Anacortes , Washington
Good afternoon,
What is your weight fully stocked with gear? My friend is looking for one? I am in Anacortes.
Mark
Setterlane is offline   Reply With Quote
Old 08-08-2020, 11:53 PM   #3
The Maximum trailer capacity is 7600, with the base with LP and batteries but likely not full tanks listed as 5979. Fully stocked with gear varies a lot with different folks, and even with us depending on the trip.
Serenity 27FB :: 2015 Airstream International Serenity Nonya Airstream Registry Discussions 0 08-15-2019 07:10 PM
Serenity :: 2013 Airstream Serenity International adiben Airstream Registry Discussions 0 02-21-2013 01:33 AM
