Meticulously maintained, updated and taken care of. This Baby has been under cover, non smoking, no pets,title in hand and "Ready To Roll". Delivery negotiable. Up dates listed.
1. All Led lighting
2. Propane bottle aluminum cover
3. All stabilizer jacks; removed, painted with 3 coats of paint.
4. Extension installed on all stabilizer jacks
5. Label tire Pressure, Torque and jacking locations
6. 2 ea.
12 Volt receptacles installed in BR
7. Installed shelf in BR
8. Sewer outlet updated from factory raised amp; extended
9. Propane safety alarm wired to battery shutoff
10. Screwed all molded plastic trim to bottom skin amp; sealed to mouse proof
11. Safety High Visibility reflector tape placed around perimeter of trailer
12. LED light installed in refrigerator motion activated
13. Door actuated automatic light in closet
14. Sound buffered refrigerator fan with new ball bearing fan
15. Lower helper fan in refrigerator with bypass switch
16. All inside switches marked for ON/OFF
17. Additional storage tubes installed under trailer
18. Installed hot water heater valve drain rock guard support
19. Mirrored film on windows
20. Moisture monitoring alarm installed pump
21. Updated HD 30 Amp electric connector receptacle
22. Hooks installed inside
23. Water/anti freeze by pass valve installed
24. Painted front frame
25. Installed HD electric jack in front Wired for rear camera
26. 7 pin Umbilical cord and jack cord holder
27. Installed bumper and storage box
28. Covered exterior propane pipes with rock shields
29. Installed 2.65 inch axle lift kit
30. Drain valve on water heater
31. with digital read out
32. New 120 volt exterior plug and inlet
33. All switches marked for on/off
34. 2 HD 120 volt receptacles with USB ports
35.
36. Water filter under sink
37. Solid stainless steel lug nuts
38. Inside closer handle
39. Level parking Gage
40. Bidet toilet
41. 2022
42.
43.
44. 100 A Hr. battery and custom aluminum case, on/off switch, tire pressure switch, booster, 3 transmitters and monitor
45. Installed safe
View this ad at Airstream Classifieds -
2014 Airstream Sport 16 - Missouri
