This beautiful Airstream started life as an Ocean Breeze edition. Quite a few modifications were done, including new modern drawer and door handles and Ultra Leather cushions. We are the second owners and have traveled the country for two years without any major issues. We hate to let it go but we don t travel full time anymore and have downsized. It is 14 years old so some nicks and scratches are to be expected. It is being sold as is.
Solar panels 400 watts. Xantrex 2000 watt inverter. Disc brakes. 16 inch tires. AGM batteries. NEW propane tanks. Ultra Leather custom upholstery. Luxury Vinyl Plank flooring. LED lighting. WeBoost cell signal booster. Window shade package. Fiamma bike rack. Repacked bearings, spares included. NEW brake pads, spares included. ProPride hitch. Fantastic Fan rain shields. Easy Start for A/C. NEW circuit board for A/C. Full awning package.
7300 lb GVWR. 7000 lb axle system. 5870 UBW. 1030 NCC. Styled aluminum wheels? Stabilizer jacks with pads, 4. Double steel step. Electric hitch jack. Spare tire bracket.
30 lb propane tanks. 2 LPG tank cover. Enclosed and insulated underbelly. Solar stone guard. Wrap protectors. Blue and white striped awning package: curbside, roadside and rear awnings. Solar gray windows.
Premium laminate cabinets. Accent wall in Kaleidoscope Aluminum. Bamboo detail on lampshades and upper cabinets. Pull shades at kitchen window and lounge windows. Exposed aluminum interior. Laminated countertops.
Fiberglass shower. Toilet. Stainless steel sink. Mirrored cabinet above sink. Storage cabinet.
Under bed storage with hydraulic lift. Queen bed with mattress. Wardrobes, 2. Customizable bedside shelf units, 2.
Flip up counter space. Sink cover. 18" round stainless steel sink. Pull out pantry storage. Storage drawers. Overhead storage cabinets. Under sink storage.
13,500 BTU A/C with heat pump and Comfort Control Center. 25,000 BTU furnace with electric ignition. 3 burner cooktop with oven. Range hood with vent and light. Fantastic Fans, 2. Bathroom exhaust fans, 2. 6.0 cu. ft. 2 way automatic refrigerator. Probeless tank monitoring system. 6 gal. water heater with electric ignition. Fire extinguisher. Smoke, LPG and carbon monoxide detectors.
Overhead storage cabinet. Storage below lounge and dinette seating. Decorative throw pillows.
Samsung TV with swivel wall mount. Radio antenna. Speakers, 4. Radio/CD receiver. TV antenna with outlets. Cable/telephone hook up.
Roof mounted solar panels, 400 watts. Xantrex 2000 watt inverter. AGM batteries, 2. 7 way card cord junction box. 110 volt/12 volt power center with 55 amp converter.
12 volt ATC fuses. LED lighting. TV jack with
12 volt outlet, 2. 120 volt exterior outlet. GFI outlets. Patio light. Electronic battery disconnect.
30 lb steel LPG bottles, 2. Automatic 2 stage regulator. Shower head with shut off. Water heater by pass kit. Lockable water fill. Water pressure regulator. 39 gal. fresh water tank with drain valve. 39 gal. black water tank. 37 gal. gray water tank. Safety chain hook 11,700 lb rating. Sewer hose storage tube.
720 lb hitch weight. Exterior length: 25' 11". Exterior width: 8' 5.5". Interior width: 8' 1". Exterior height with AC: 9' 7". Interior height: 6' 5". Hitch ball height: 17.75".
Known issues that need to be addressed: Oven door screw/spring replacement, curtain elastic replacement, laminate edge regluing in kitchen, minor scratches on exterior, tank probes need cleaning.
X Chocks, 2. Simple Human soap dispensers, 3. Magnetic knife rack. Rivet gun with rivets.
View this ad at Airstream Classifieds -
2007 Airstream International CCD 25 - California
