This trailer is an Airstream Excella Classic 1000 '97 thirty foot wide body. Approx. 255 square feet that will sleep 6. Layout features a rear bed, middle bath, providing maximum living space. We are the 2nd owners and only used the trailer 3 times after purchasing it. Never had red numbers on it.
Clear title in hand. Priced to sell at 34,500
Interior Features:
- Queen bed floor plan
- Residential quality, solid brass hardware and solid oak cabinetry. Three cedar lined wardrobes with hardware framed mirrored hinged wardrobe doors.
- Nine screened windows that open outward to full extension and include day/night shades. Panoramic view in the front lounge area.
- Original fabric valances.
- 3 Burner range. New microwave. Range hood / vent.
- Water facet with purifier.
- 8.0 CU FT 2 way refrigerator.
- Fiberglass shower stall.
- Oak hardwood table.
- Writing table and chair storage with two Airstream folding chairs.
- Convertible dinette, 42 in by 72 in.
- Folding sofa bed.
- Carpet throughout offers temperature and sound barrier.
- Original working heat and air. 13,500 BTU A/C
- Bluetooth CD, AM/FM stereo.
- Two "Fantastic Fans".
- Original adhesive on headliner needs upgraded.
Exterior Features:
- Aluminum wheels.
- Spare tire bracket.
- Original blue canvas "Zip Dee" awnings.
- Aluminum step with extension.
- Molded rear bumper/ roll out storage.
- Replaced screen door gasket and replaced entry door seal in Sept. 2018.
- CS Patio awning and CRT support 16 4.5.
- 3 PC solar gray stone guard.
- Replaced both roadside lower wrap protectors in Sept. 2018.
- Panoramic windows.
- Two 40lb aluminum propane tanks recertified in September 2018 and never used.
- LPG bottle cover.
- Original exterior lighting package.
- Sept. 2018 replaced drums, brakes, and bearings. Packed new bearings and installed new grease seals.
- Installed water pump bypass kit for winterizing.
- Age appropriate dimples.
Running Gear / Systems /Specifications:
- Original owner s manual included.
- Exterior coach length 30.
- Exterior height 9 8.
- 12 Volt disconnect switch.
- 12 Volt circuit breakers.
- 12 electric drum brakes.
- Electric hitch jack.
- Electric stabilizer jacks.
- Automatic 2 stage regulator.
- Deluxe tank monitoring system.
- Water Tank with drain valve, 54 Gallons.
- Black Water Tank with flush, 37 Gallons.
- Stainless steel A frame protectors.
After we purchased the trailer in Sept.2018 we took it straight to an RV dealer that has been in business over 50 years and is an Airstream 5 Rivet Dealer. They water tested for any exterior leaks none were found . We had all the windows resealed. Resealed around the water heater. We had the center and lower beltline trim replaced. All the clearance lights, roof edges, 5 roof vents, 3 rear segments on top were all resealed.
All original.
Don't hesitate to reach out if you have any questions.
View this ad at Airstream Classifieds -
1997 Airstream Excella 30 - Georgia
