This Airstream was manufactured in 1988, which is historically within Airstream's best years 1987 1989 . This Airstream has been meticulously maintained, with extensive upgrades added over the years. Pictures of this trailer have appeared on the back cover of Airstream's magazine, Blue Beret, three times, with a feature story in the 3/18 Blue Beret.
Some of the Upgraded and/or New Features added to the Airstream include:
3 Solar Panels with a
1500 Watt Trace Inverter
4 Condorde SunXtender AGM Batteries in 2019
Replaced Electrical Lines to/from the Batteries with Heavier Gauge Wire
Solar Boost 2000E Voltage Controller w/Built in Hi/Low Protraction Switch
New Water Heater
New Furnace and Water Heater Controls
Electric Water Heater Addition with On/Off Switch
Catalytic Heater Mounted on a Rotating Bracket
Kenwood HD Radio w/Bluetooth amp; USB Port
4 New Polk Audio Speakers
New TV Antenna
4 GE Bright Sticks Added to Window Valances
12v Fluorescent Lights Added to Center of Sofa and Bed Panels
New Zipdee Awnings in 2010
2 New Auto Close Fantastic Brand Vent Fans/Covers in 2014
New Dometic 2320 Refrigerator in 2014 w/Added Sidewall Insulation and Coil Cooling Vent Fan
Front Ceiling Light Converted to LED
Outside Running Lights Converted to LED
Added New Cabinet Over Right Side Bed
New Custom Made Curtains
New Inner Spring Mattresses
Changed to Gas Shocks on Axles 2010
5 New 10 ply Carlisle Tires in 2013
Reinforced Under Sofa Drawer and Added Heavy Duty Roller Bearing Brackets in 2019
Forward Show Wall Cover Replaced with Vinyl Sheeting
New Fresh Water Fill Pipe
Added Two Under Belly Storage Tubes
Frame Mounted Trailer Hitch Added for Bike Rack
Reflector Mud Flaps Added to Wheel Wells
New Toiler in 2018
New Water Pump Mounted on Rubber Base
Water Line Pressure Tank Added Near Pump
Pump Space Under Closet Lined with Insulation
New Bathroom Vent Motor and Fan in 2014
CB Mounted Above Left Side Bed w/External Antenna Mounted to Fridge Vent Cover
Wheel Bearings Repacked and Seals were Replaced
Added Extra Braces to Entry Steps
New Waste Gate Valves 2 in 2018
Here is a partial list of the maintenance routine for this Airstream:
Oak Cabinets Regularly Treated with Lemon Oil
Brakes Inspected 2018
Water Heater is Drained and Flushed at the End of Each Season
Exterior is Waxed Annually
Window Seals Are Treated Twice Annually
Window Frame Channels are Cleaned Twice Annually
Dark Gray Lower Body Panels are Inspected and Painted Annually
Belly Pan Seams are Sealed Annually
Also available is a 2000 Chevy 3/4 Ton Suburban that has been towing this Airstream for 20 years. It is perfectly balanced and ready to hit the road immediately. Purchasing the two together would make a perfect package. Asking Price for the Suburban is 12,000.
View this ad at Airstream Classifieds -
1987 Airstream Sovereign - Arizona
