Old 10-19-2020, 01:44 PM   #1
1978 28' Argosy 28
HOOKSTOWN , Minnesota
1978 Airstream Argosy 28 - Minnesota
17,777 or BEST OFFER
Bought in 2015 from original owners estate in San Bernardino CA. Replaced front and rear airbags, Supersteer steering linkage, shocks, brake calipers, hoses, master cyl. AC compressor and hoses. Fuel pump, dist, H20 pump, Edelbrock carb, alt, starter, blower motor. rebuilt trans. Installed Gear Vendor overdrive in Oct 2019.Shorten driveshaft, new u joints and center hanger. Dakota digital Cruise control, Classic radio. LED clearance lights, poly sway bar bushings. packed front wheel bearings. Rear drums pulled grease seals, brake shoes and wheel cylinders replaced. Engine replaced with GM factory remanufactured long block at 93 K miles. New mufflers and tail pipes. New oil press, H20 temp and Voltmeter. Replaced front seats.
The Gearvendors overdrive reduces engine RPM from 2800 to about 2200 at 60 MPH.
Rear tires at 50 percent.
Replaced, rear A/C, H20 pump, furnace, facets, dump valves, Univolt, entrance steps. Installed Laun floor on top of original floor installed vinyl flooring. Insulated forward cabin floor, carpeted and trimmed cab area. Custom reupholstered couch and trim panels. Converted rear bed with new IKEA full size mattress. Custom mounted Samsung TV wired for cable.
Have original rear side windows, Current windows installed by original owner.
Original NuTone Food center blender and mixer. Never used.
Garaged for most of life in San Bernardino, CA. Frame is still about 75 percent black paint.
Includes all factory service and part manuals.
The most recent trip was earlier this year from SW Minnesota to Southern California and return.
Has 144,588 miles........
View this ad at Airstream Classifieds - 1978 Airstream Argosy 28 - Minnesota
1978Argosy28 is offline   Reply With Quote
1978 Airstream Sovereign 31 - Minnesota rcarter Airstream Classifieds 0 07-29-2015 07:38 PM
1978 Airstream Sovereign 31 - Minnesota rcarter Airstream Classifieds 0 11-17-2014 05:38 AM
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
1978 22 foot Argosy vs 1978 22' Minuet DonDiego All Argosy Trailers 37 12-02-2009 08:34 PM
