1977 AIRSTREM
SOVEREIGN Length : 31 VIN/Serial Number: I31 T7J 1875
Please watch the video tours and view the entire video album!
Refurbished chassis belly pan was taken off, frame was repaired as needed. Rear end rebuilt before and after in album . Frame was painted with POR15 coating.
New torsion axels installed, new brakes.
Interior panels not removed, so original wiring and insulation. Plumbing was redone see below . Rear bath framing was rebuilt with new plywood. Bath fiberglass interior end cap, bath, countertop, sink was professionally epoxy painted.
New window gaskets, screens. Custom made screen SS door guard on main entry door.
Polished to bright finish.
Original ZipDee front/door awning package. Most hardware pieces locking and ratchet pins, travel safety latch etc were all replaced with new.
New stabilizers, New Tires, New heavy duty REESE load leveler and friction anti sway kit installed, New Electric jack installed
Electrical
New LED running lights
30 Amp Service, hardwired cord
New LED puck lighting added. 22 LED puck, color temp adjustable lights, remote control or wall switch operation, added in 4 zones
LED programmable strip accent lighting in main cabin and above all roll top doors throughout.
New INTELI POWER 45 amp convertor/charger.
12v Battery Cut off switch
LP amp; CO detectors installed
Appliances Existing/Original Refurbished:
Rooftop Armstrong AC unit reconditioned and working perfectly
Original Dometic refrigerator. Reconditioned and interior epoxy painted. Works on both propane and 120v AC.
Original LP Furnace. Reconditioned, tested and new control board installed.
New Appliances:
New 2 burner gas stovetop
4 Way Galanz Microwave under counter
Farberware under counter mini dishwasher installed and plumbed in. Removable for winterization if desired.
New vent fan s 4 in total
Original date stamped 1976/1977 aluminum Propane tanks: New tank values professionally installed and both tanks re certified.
Interior
New custom cabinetry doors, fixtures. All interior cabinets cedar lined.
Front bed area is a custom modified modular sofa system. 7 piece with storage under each seat. Each module can be moved as desired to create any layout as space allows Rear street side couch/bed is a dual piece, pull out bed of custom 8" memory foam mattress. Additional sleeping: The breakfast bar can be another single sleeping platform.
Hidden cubby under pantry which has a Shark robot vacuum cleaner installed.
Custom built main area/salon cabinet hides a motorized 4K 32" pop up SAMSUNG 32 inch M5 Smart Monitor/TV. Cabinet also has storage for up to two 5 gallon bottled water jugs.
Rear custom cabinet adjacent to the breakfast bar/work station hides a 2nd pop up 27" 4K Samsung Smart Monitor/TV.
Android Computer Head Unit is the stereo and a full Android tablet
Custom speaker mounts 2 front two rear that have the trailers name etched into them and also light up and glow with LED.
Dual
12V and USB panels installed throughout the trailer 8 USB ports total throughout .
Plumbing
New PEX plumbing throughout, new ball shutoff valves inline for hot water tank bypass and loop, hot and cold drain lines, new city water connection, winterization vales etc...
New water pump
New Dometic full size ceramic bowl RV toilet
Reconditioned and insulated freshwater, gray amp; black water tanks.
Known issues:
Exterior:
Dent and rippling on curb side rear lower curved panel, just behind the water heater.
Belly pan has a visible vertical crack on the curb side, near the rear of the trailer.
Interior: 1 small crack 4" at most in both the front interior fiberglass end cap and the rear bath end cap.
View this ad at Airstream Classifieds -
1977 Airstream Sovereign 31 - Wisconsin
