We took on this big beautiful Airstream with the intention of doing a top to bottom custom restoration. Sadly our plans have changed and we are now offering this thorough frame and shell restoration for sale. The buyer of this trailer is someone looking for a solid foundation to build their dream Airstream upon and skipping a lot of the drudgery and heavy lifting so to speak.
This trailer is being sold as a 'Stage One' Completed prepped, reinforced, restored frame, 3" lift, floor and no leak shell without an interior but includes everything listed below. It's transport ready and and can be towed to wherever you need it. It's ready for 'Stage Two', which is interior fitments and your vision for it. CLEAR TITLE IN HAND
Exterior hardware, trim, badges, awning etc. were removed for renovation and left off to better accommodate the future polishing. All those bits and pieces are included just not installed. The original 70's interior fitments were gutted and mostly disposed of but I kept some of it the stove, heater, control panel, furnace and a bunch of random extras all included if you want it. Pickup in SLC near Liberty Park or delivery available within 30 miles.
The front page photo is the Airstream in it's sale condition. I can't seem to re order the photos on this site for clarity but all the pictures of it on the street in front of my house with the red truck are the most current and it's the state of the Airstream being offered for sale. It's empty, no insulation or interior skins. The rest of the pictures are showing random stages of the renovation and everything else that is included. I'm happy to text photo's for clarity or live stream a walk through.
Summary:
- You get a freshly painted and restored steel reinforced 3" lifted frame
- 2016 Dexter Torsion Axles, 4 great tires,
- A no leak shell, no window or door leaks
- Every window, door, rivet, skin seam and weather seal rubber gasket has been checked, gone over, replaced, disassembled and fixed
- New MDO waterproof Plywood flooring with epoxy impregnator sealed edges and glued and bisquited joints
- Completely new aluminum perimeter floor channel. This connects the shell and floor to the frame
- Two new 31 gal black and gray waste tanks installed but not plumbed.
- Original 45 gallon fresh water tank
- Misc. various new plumbing components
- Full length Zipdee working awning and components with reinforced support arm attachment points on the trailer.
- All the original aluminum exterior trim bits, badges and pieces with new 1" amp; 1/2" accent trim strips in blue,
- Four original banana aluminum corner belly wraps
- Original gas stove
- Original gas Thermex radiant wall heater
- 8 year old furnace with no issues
- Wheel covers
- The old interior aluminum mouse fur skins and exterior belly skins for templates
- Newer Duracell Marine grade 12v battery
- New marine grade 12 gauge brake wire
- Newer but old 4 stage power converter/ charger output 13.6 v 105 130vac
- Newer but old water pump
- Complete tail light assembly's
- New door handle latch/lock
- A couple of new aluminum exterior skin pieces replaced
- Bumper storage compartment aluminum hinged lid
- Two original large aluminum propane tanks with valves and regulator / with tank clampdown bracket
- Original stabilizer towing hitch
- A spare tire
- 3 of the four original bottom mounted frame support/leveling jacks missing one
- 7 pin wire towing harness/connector
- New never installed Dometic 320 Ceramic High Profile Gravity Flush Toilet in white
- Hitch jack wheel attachment, hitch jack foot attachment,
- Two 4 x 8 x 2 sheets of rigid pink foam board insulation to use as below floor insulation
- Original Airstream user manual with notes
- Front window rock guard/shade
- Original window screens
- Three of the four original hubcaps lost one
- Power docking hookup cords and adapters
The un summarized list: The restoration details.
Message me and I'll send it to you. It puts me over my word limit and It's not letting me post.
View this ad at Airstream Classifieds -
1975 Airstream Sovereign 31' 31 - Utah
