Old 08-25-2020, 09:39 PM   #1
moab , Utah
1968 SILVER STREAK SABRE - Utah
SALE PENDING...
This SMALL EASY TO TOW 1968 Silver Streak Sabre has been professionally resto modded to self sustain for extended periods off the grid, and be fully functional when the temperature dips well below freezing.
This short 20 feet long total , narrow 7.5 feet wide , and lightweight 2880 pounds is easy to tow and fits just about anywhere. The ride height is raised to allow access to unimproved dispersed campsites.
Despite the compact exterior dimensions, the interior is spaceous enough to fit a permanent full sized bed, large dedicated shower, full kitchen, loveseat/dining area, and more storage than I can fill. The original floor is rock solid; it is finished with waterproof polycuramine.
The commercial grade solar system effortlessly powers the modern energy efficient marine grade appliances.
A Natures Head Composting Toilet elliminates the hassles of dealing with sewage. Even with full time use by two people, the soilds only need to be emptied once per month; not an unpleasant process either.
The exterior shell is riveted aircraft aluminum just like an Airstream. It is exceptionally straight and leak free, but does show some minor scuffs and discoloration on the factory hardcoat anodized skin. The windows all open smoothly.
The build quality on this camper is unmatched by anything I have seen. All of the exterior fittings are aluminum or stainless. The interior is built with hardwood laminate. The wiring is tidy and cables oversized to minimize power losses. The plumbing a stainless steel work of art. No cheap parts were used and no corners cut!
Solar System
3ct. 100W Renogy Panels, Custom aluminum roof entry box, Victron 100/30 MPPT Charge Controller, 2ct. Windy Nation 100ah AGM batteries System compatible for drop in Lithium battery upgrade
Shore Power
Sterling Pro Charge Ultra 40A programmable battery charger
Interior Electrical
Isotherm 130L compressor fridge, Victron BMV 700 battery monitor, bedside dual usb charging port, stainless marine grade light fixtures with glass lenses.
Heating
Dickinson Newport P9000 propane fireplace, Suburban 19k BTU furnace
Plumbing
Precision Temp RV 550 on demand water heater, 30 gallon freshwater tank, on demand water pump, stainless steel acculuminator tank, PEX plumbing with brass fittings, quick and simple to winterize
Four Season Capability
Extra insulation added in no longer necessary factory appliance vents, entire plumbing system located in heated space, batteries properly/safely moved indoors, dual heat sources for redundancy.
Towing
3500 pound Dexter axles, eletric brakes, 5 new tires
LOGISTICS
I am located in Moab Utah and willing to show the camper locally, deliver anywhere in the continental United States at fuel cost, or work with your shipping agent.
WALKAROUND VIDEOS AVAILABLE UPON REQUEST!
View this ad at Airstream Classifieds - 1968 SILVER STREAK SABRE - Utah
gjeep9754 is offline   Reply With Quote
1968 silverstreak Hardib00 Airstream Classifieds 0 04-24-2014 08:09 PM
silverstreak trailer delux clipper 1968 vintage airstream eBay Watch Airstreams on eBay 0 09-07-2012 09:30 PM
silverstreak trailer delux clipper 1968 vintage airstream eBay Watch Airstreams on eBay 0 08-23-2012 04:40 PM
