Old 09-02-2023, 02:42 PM   #1
1967 30' Sovereign
Kingman , Utah
1960 Airstream Tradewind 24 - Arizona
A recently completed full luxury restomod featuring the latest and greatest components, appliances, and Airstream construction techniques. Fully equipped for on and off grid stay, using smart technology and intuitive design to achieve maximum simplicity and ease of use. Great for traveling, an AirBnB or guest home. Absolutely gorgeous inside and out!
Specifications:
1960 24ft Airstream Tradewind
New Dexter/UFP single adjustable torsion axle, hubs, electric brakes
Approx. 4k dry and 450lbs tongue weight
30amp service
33 gallons fresh water, 10 gallons black water, 33 gallons gray water, 60 lbs lp gas w/monitors
200ah smart lithium Renogy battery w/Bluetooth monitoring
200w Renogy Solar with Renogy charge controller with receptacles to easily add more panels
3000w SunGoldPower pure sine wave smart inverter charger with built in surge protection
Closed cell spray foam Tiger Foam insulation
Foamular NGX subfloor insulation system
New belly pan
Dometic 15k btu Duo Therm A/C with heat pump
Suburban low profile high efficiency gas furnace
MaxxAir Deluxe fan
Maxim Skylights solar dome
Vitrifrigo stainless fridge / freezer
Dometic stainless range / oven
Convertible couch / bed
Shurflo water pump, strainer, accumulator, and silencing kit
Pex plumbing throughout
Insulated freshwater and heated gray tank
Level sensors on all tanks with monitor
Fogatti Instashower 8 gas tankless water heater
Solid surface counter tops
Quartz sink
Solid brass faucet
Sealed Solid white oak cabinetry faces with painted Baltic birch boxes and drawer boxes, wrought iron pulls, and soft close slides
Premium zippered couch upholstery with American materials
Casual Elements table, with elm style bench
Fiber reinforced polymer shower with acrylic molded shower pan, travertine bench, teak shower mat, adjustable flow brass shower head
HepvO waterless p trap valves for each drain 3
Petite stone vessel bathroom sink
Dometic low profile RV toilet
12v LED lighting throughout
Two 12v receptacles to go with the 110 outlets
New wiring amp; electrical throughout
Full Alpine sound system with Bluetooth capability
Brooklyn Bedding rv queen mattress with premium linen sheet set, duvet cover, duvet, and pillows included
BAL jacks at rear of trailer
Curt tongue Jack, comes with Curt sway bar amp; hitch along with Ox Block, leveling blocks, and wheel chocks
New tow safety chains
2x 30lb Flame King lp gas tanks with new regulator and new copper gas lines fittings
Original wheels repainted
New tires including full sized spare, Jack and lug wrench included
New baby moon hub caps original rusty caps go with it
New tempered glass windows
Insulating shades
New polycarbonate rock guard
New folding step
New sealed subfloor
Forbo Marmoleum sheet flooring
Comes with new freshwater hose, filter, rv toilet paper, flooring conditioner, gasket conditioner, solar add on adapters, 30amp power cord, sewer hose and sewer stands
New keys for front door, keys and new lock for rear cargo hatch
All gaskets have been replaced
2x fire extinguishers on board, 2x smoke detectors, lp gas detector, carbon monoxide detector
New tail lights and new LED running lights
Valterra wastewater valves
Seams sealed inside and out
Original patina preserved
Compared to a new Airstream or purchasing/commissioning through others, this is a fantastic deal!
We have a full walkthrough tour video on YouTube we can message to you!
We do accept commissions, to learn more visit our website at patinaairstream
View this ad at Airstream Classifieds - 1960 Airstream Tradewind 24 - Arizona
Dreamlander is offline   Reply With Quote
1960 Airstream Flying Cloud 22 - Arizona cabmike1954 Airstream Classifieds 0 10-05-2018 07:48 AM
1960 Airstream Flying Cloud 22 - Arizona cabmike1954 Airstream Classifieds 0 04-01-2018 12:14 PM
1960 Airstream Tradewind :: 1960 Airstream Tradewind streaming24 Airstream Registry Discussions 0 09-03-2015 02:53 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
