Old 11-27-2017, 12:09 PM   #1
1968 26' Overlander
N. Muskegon , Michigan
Renogy Solar Panel and Controller
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
New, in box, Renogy 100 solar panel and controller w/ mounting brackets and wiring.
This has not been installed or used and needs a good trailer to be installed upon.
Renogy's 100 Watt 12 Volt Monocrystalline Solar Panel is Renogy's most popular product! High in power but sleek in size, this 100W solar panel is the perfect item for off-grid applications. Use it for your RV when camping, or during beach trips with the family, either way this monocrystalline panel provides you with the most efficiency per space. With a set of MC4 connectors coming directly off the panel, connecting with other Renogy panels is a breeze. If off-grid solar interests you, then start with Renogy today!
Reliable
Advanced encapsulation material with multi-layered sheet laminations to enhance cell performance and provide a long service life.
EL tested solar modules; no hot-spot heating guaranteed.
Bypass diodes minimize power drop caused by shade and ensure excellent performance in low-light environments.
TPT back sheet ensures smooth performance over a long period of time.
Durable
Guaranteed positive output tolerance (0-3%); withstands high winds (2400Pa) and snow loads (5400Pa).
Corrosion-resistant aluminum frame for extended outdoor use, allowing the panels to last for decades.
Anti-reflective, high transparency, low iron-tempered glass with enhanced stiffness and impact resistance.
IP65 rated junction box provides complete protection against environmental particles and low pressure water jets.
Versatile
Can be used for many different applications.
Ground mount compatible.
Compatible with on-grid and off-grid inverters.
Installation Ready
Pre-drilled holes on the back of the panel allow for fast mounting and securing.
Pre-drilled holes included for grounding.
Compatible with different Renogy mounting systems such as Z-Brackets, Pole Mounts and Tilt Mounts.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...nd-controller/
pipers0511 is offline   Reply With Quote
Renogy, Am Solar, Grape Solar, Go Power what's the best or what are you running?why? ASTailgate Electrical - Systems, Generators, Batteries & Solar 30 12-15-2021 04:00 PM
portable solar: Zamp vs GoPower vs Renogy bliss Generators & Solar Power 68 11-19-2021 10:28 AM
Zamp or Renogy portable solar fran&frank Electrical - Systems, Generators, Batteries & Solar 73 07-16-2017 11:18 AM
Renogy vs Zamp Wesair Electrical - Systems, Generators, Batteries & Solar 5 09-18-2016 08:07 PM
Renogy 100 watt suitcase AWCHIEF Generators & Solar Power 24 02-07-2016 09:25 AM
